Old 12-30-2019, 04:03 PM   #1
Cold bunk house.
I just upgraded my trailer to a coachman freedom express ultralight. The first night the kids were freezing and no heat was making it to them. This was the main reason we upgraded for the kids to have there own beds. Does anyone have suggestions?
Diamond Donny is offline   Reply With Quote
Old 12-30-2019, 04:08 PM   #2
007matman's Avatar
Ceramic space heater.. add fans to blow in heat from the living area.
007matman is offline   Reply With Quote
Old 12-30-2019, 04:09 PM   #3
welcome. many a threads about crushed or unhooked duct work causing improper air flow. If possible check air flow and looked for crushed or unhooked duct work. quickest easiest fix if not paying for your own electric is an inexpensive electric space heater.
Kimber45 is offline   Reply With Quote
Old 12-30-2019, 06:33 PM   #4
bikendan's Avatar
It would help if you posted year and model number, since you don't have it listed in your profile. That way others that own your model can be more helpful.
Are there furnace vents near the bunks?
Old 12-30-2019, 07:24 PM   #5
It is a 2019 257bhs freedom Express. Yes there is one underneath the bunks
Old 12-30-2019, 07:58 PM   #6
If it is adjustable be sure it is open. To test if it is hooked up, cover all the other vents and see if air flows out.
Old 12-30-2019, 08:44 PM   #7
bikendan's Avatar
Probably blocked ducting.
Old 12-30-2019, 08:55 PM   #8
Thurman's Avatar
I have a '14 Freedom Express with slide/bunks. Like the OP the first time we camped in cold weather I found that the bunk room was cold. There are no heat registers in the bunk room. I found one in the closet and thought how odd. Turned out it was a vent for the water heater. My g'son's are old enough so I bought a quartz space heater for their room
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 12-30-2019, 09:18 PM   #9
Dodge Guy's Avatar
My 07 Cherokee 32B had the opposite problem. The bunk room was like an oven! What I did here was block about 2/3's of the vent. This forced the hot air back out through the other vents.
Do you feel anything coming out of the vents? Maybe you will need to block off another vent to force the heat back there. Just takes some time and patience.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 12-30-2019, 09:31 PM   #10
To balance a quiet with comfort in the bunkhouse, we shut the bunkhouse door when the kids go to sleep but open it back up when the adults go to sleep.
Skip12 is offline   Reply With Quote
Old 01-02-2020, 11:12 PM   #11
I checked the heater ducts and all are working.I am going to try to insulate underneath the bottom bunk and use reflective on the windows. Then add to fans ti blow air in to the bottom bunk.
Old 01-03-2020, 01:07 PM   #12
007matman's Avatar
Something like this can really help.. we have several of them.. one that is always in the camper.
Small enough to be out of the way but moves a lot of air. You could probably just leave it sitting in the doorway. Click image for larger version
bunk, bunk house
