Old 01-20-2022, 04:46 PM   #1
Coleman Mach 15 not level?
So I was on the roof the other day and I noticed my ac level. It’s a Coleman Mach 15k btu unit. The front metal base is higher than the rear. I looked and the install manual and read about the tabs. When I checked to see if the tabs where they’re supposed to be, I noticed no tabs. So I am not sure if the front is loose. Now when the air does come on I notice a vibration in the trailer. Here is a pic of the ac on the roof. Click image for larger version
So does this look normal or should I tighten down the front bolts? I wish coleman used torque specifications instead of visual tabs.
getastro is offline   Reply With Quote
Old 01-20-2022, 04:53 PM   #2
Originally Posted by getastro View Post
So I was on the roof the other day and I noticed my ac level. It’s a Coleman Mach 15k btu unit. The front metal base is higher than the rear. I looked and the install manual and read about the tabs. When I checked to see if the tabs where they’re supposed to be, I noticed no tabs. So I am not sure if the front is loose. Now when the air does come on I notice a vibration in the trailer. Here is a pic of the ac on the roof. Attachment 268012
Doesn't have to be level . your unit looks good as is . you can tighten the hold down bolts if you feel it's loose .
MR.M is offline   Reply With Quote
Old 01-20-2022, 05:17 PM   #3
Thanks, just was not sure since you see a lot more of the gasket in the front. Not looking for any issues with leaking.
Old 01-20-2022, 05:27 PM   #4
Had you recently had the roof coated? (looks shiny clean compared to the A/C cover)
If so and someone removed the A/C for sealing, they may not have tightened it even. Was a new seal used? Does it leak? What made you notice this just now?
Maybe none of this even applies? Just trying to know the whole story.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=88
Old 01-20-2022, 05:38 PM   #5
I recently re-coated the roof, I did not remove the a/c. I was thinking about replacing it with a mini split system. I have decided to hold off on that because of the price of the copper. It does not leak, just was not sure if that slight slope was normal.
Old 01-21-2022, 09:46 PM   #6
Go inside?
The hold-down bolts are not supposed to real tight. The spec often is to compress the foam gasket to 1/2 its original thickness. You could check by giving each bolt 1/8 turn and see if they appear to be equally tight.
To be a little more rigorous, go on the roof and see if the gasket appears to be compressed to the same size on all sides.
Larry
Larry-NC is online now   Reply With Quote
Old 01-21-2022, 10:00 PM   #7
Thanks for the reply, I know for a fact the gasket is not compressed equally all the way around. It is more compressed in the back of the unit then in the front.
Old 01-21-2022, 10:14 PM   #8
Herk7769's Avatar
I hate to be the one to break this to you, but that AC is going to leak eventually.
The foam gaskets can not be reused if they are removed and when a new one is installed it must be torqued evenly until the yellow torque tabs just contact the roof.
See attached photos.
Overtorqued AC seals will not allow the seal to conform to the roof material properly and eventally water will work its way through the gaps in the seal until there is a path for water intrusion.
ID:	268049   Click image for larger version
ID:	268050   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 01-21-2022, 11:40 PM   #9
I did not remove the ac, it’s still up there from the factory. The tabs are missing so I can’t tell if the front is torqued correctly. That’s the issue
Old 01-22-2022, 11:27 AM   #10
If it's been that way from the start and hasn't leaked in all these years, why mess with it? Just because it looks funky, it doesn't appear you've mentioned it being a leaking an issue. Am I missing something?
coleman
