12-31-2015, 01:23 AM
Condensation
Just wondering if anyone has had a condensation issue on the bed frame over the storage area and if so what did you do to prevent it?
I'm getting condensation between the mattress and the particle board bed frame.
I have a Wildwood 32bhds stored in a shop and utilizing to sleep in while remodeling the house, so running the heater while in the trailer. Thanks in advance for any responses.
12-31-2015, 02:24 AM
Buy a cheap dehumidifier on Amazon. You would be surprised at the amount of water it collects in a 24 hour period. Heater is fine but it won't do much for the humidity. Heater+dehumidifier is the way to go. We bought & have been happy with: Ivation GDM20 Thermo-Electric Dehumidifier. It was around $40.
12-31-2015, 03:05 AM
Who Dares, Wins
I have also heard a few people use the foam insulation board to make a better air gap between the hot mattress and cold storage area. I also second the dehumidifier.
2015 Chevy HD D-Max
2022 Impression 315MB
12-31-2015, 05:51 AM
Are you calling the (Propane Furnace) the heater? Youroo!!
12-31-2015, 12:38 PM
Yes the propane furnace...
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
12-31-2015, 08:05 PM
So you have a RV inside a Building and you are running a Propane Furnace,this is a (DEATH WISH)!! STOP This NOW! Youroo!!
12-31-2015, 08:14 PM
statistics
haven a blast
12-31-2015, 08:19 PM
Popcorn
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
12-31-2015, 08:56 PM
Oklahoma Proud
Yep this could be really bad. Might as well run a vehicle in the shop....maybe a little safer than that...hope the doors are all open. Good luck op! I think condensation would be a moot point.
12-31-2015, 09:11 PM
The condensation under the mattress comes from the moisture from your body penetrating the mattress and condensing on the cold bed frame. You can add a 1/2" insulating foam board under the mattress or a moisture proof mattress cover. Also put a swimming pool noodle between the head of the mattress and the wall to allow the moisture to evaporate. You can also use a fan to circulate air and prevent moist spots.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-01-2016, 04:58 AM
Condensation
Good grief. Yes the doors are open. Thanks for the concern though!
Honestly, is there that much of a concern running the furnace in a shop with both bay doors open and all windows open? I figured between the draft and the size of the shop running the heater was a moot point.
If I'm wrong please correct me.
2013 Days Camped 14
01-01-2016, 06:37 AM
This is Totally different Info than supplied in Post # 1! We have had a Member ask a Very simular Question in regards to (Living in a RV Inside a building in the Winter) within the past 30 days,we showed the Same concern for them! Better Safe than Sorry! Youroo!!
01-01-2016, 08:44 AM
I would still not do it. In your example, lack of wind would be a bigger concern. It does not take much CO to cause problems.
TST Tire Monitors
2 100W solar panels
01-01-2016, 07:57 PM
Thanks for all the advice and help.
2013 Days Camped 14
01-01-2016, 08:08 PM
Translation..
I'm still running my furnace in the shop
2016 Sabre 36QBOK
01-01-2016, 08:16 PM
You can get a 4x8 sheet of foam board from Lowe's or Home Depot for like $12 slide that under your matress.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
01-01-2016, 09:42 PM
Originally Posted by Kenny kustom
Translation..
2016 Sabre 36QBOK
Translation not needed. Don't be a troll.
2013 Days Camped 14
01-01-2016, 09:48 PM
Thanks, I'm going to check that out.
2013 Days Camped 14
01-01-2016, 09:51 PM
Thanks. I really didn't think it would be a big deal. But I will grab an electric heater, my luck is if someone warns you it's gonna happen if you don't react.
2013 Days Camped 14
01-01-2016, 09:52 PM
Not different just a shift of info. I appreciate the warning and concern. I agree, better safe than sorry.
2013 Days Camped 14
