Old 04-19-2020, 06:50 AM   #1
Kaysman's Avatar
Covid19 project
I have decided to re-caulk my 2015 Vengeance 29V during this work shutdown. As I am looking at my rain gutters I notice the “caulk”, if it is caulking, is grey and doesn’t look like caulking. My question is, does the manufacturer use a heavy duty adhesive to attach the rain gutters to the rig? Is so I don’t need to add caulk to it, but if not what type of caulk would it be? Or is it just a grey colored decor caulk? Thanks in advance for your help!
Kaysman is offline   Reply With Quote
Old 04-23-2020, 09:26 PM   #2
larry2c's Avatar
My gutter downspouts were just sort of jammed up into the aluminum extrusion so I used Geocel to attach/seal the downspout to the aluminum gutter.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 04-24-2020, 05:07 AM   #3
Kaysman's Avatar
Thanks larry2c
Old 04-24-2020, 06:34 AM   #4
FordHauler's Avatar
That ‘grey’ material is most likely butyl tape and I doubt that any caulk/sealer will stick to it. You will find that it is greasy and will collect dirt, but generally won’t fail. If it is squeezed out too much clean it off with a plastic putty knife. Clean your surface and caulk right up to it if needed. This has been my experience YMMV.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
FordHauler is offline   Reply With Quote
Old 04-24-2020, 10:28 AM   #5
Kaysman's Avatar
Thanks, I did t think there were screws in the gutter, at least I can’t find them. I appreciate the response.
