12-26-2016, 12:37 AM
Dometic 13.5 w/ heat pump
Finally fixed the AC. Even though it's a non serviceable Dometic unit. We recharged the freon. Now it works!
12-26-2016, 12:48 AM
That's awesome, but it'd be even more awesome if you provided some details on how you did it.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2019 F350 Platinum CC, PSD, 4X4, long box, SRW
Demco Glide Ride pin box
Demco Hijacker UMS 21K hitch
Did you put service valves in it? 410?
12-26-2016, 01:14 AM
I put service valves in it and had a qualified HVAC guy recharge with R410a. Now AC and heat pump works fine. We'll see how long it works. They either didn't charge it correctly when new or it has a leak. I'll know in a couple of months after heading to Florida. He put a leak sniffer on it and didn't find anything. RV dealer and Dometic told me I had to replace the unit . $1800.00 Ya right!!!
12-26-2016, 01:21 AM
Yeah, that's pricey. Good job on saving the unit (hopefully).
12-26-2016, 11:00 AM
Bill, very good. Probably took him an hour
12-26-2016, 11:47 AM
If he would have used a good set of digital gauges and a good vacuum pump, you might have known if there was a leak before you even charged it. Finding it is a different story though. I spread all my cap tubes and copper lines apart so nothing rubs. People were always complaining about leaks but no-one (techs) has ever looked for or found one to my knowledge...just replaced it. A lot cheaper to do what you did instead of replacing it when out of warranty.
2016 Forester 2401WS MBS
Life is short...eat the cookie
12-26-2016, 09:11 PM
Can imagine how long it would have taken to pull vacuum on it
12-26-2016, 10:40 PM
They make more $ if they sell a new unit 😂
12-27-2016, 12:06 AM
We've become a throw-away society.
2011 Traverse LT, 3.6L, FWD
12-27-2016, 12:34 AM
not long on a small unit....
On small systems it makes more sense evacuating and weighing the charge in per nameplate. If you use digital gauges you can tell if there is a leak right away, just sayn'
12-28-2016, 12:42 PM
I know, im an hvac tech
12-28-2016, 01:21 PM
Not meaning to steal this thread, but how do you identify if you have a heat pump unit? I have two units on my 340RK, realizing the bedroom unit is strictly a A/C unit, but I can't help but to think the main unit in the living room might just be a heat pump/AC unit. My Dometic controller goes from Furnace to Cool to Fan to Off. I do not know how to switch to heat on the main unit. The ducting system is great and so far have not needed to use the bedroom AC unit, even on hot days in SoCal. Any advice would be appreciated.
Night temps here in extreme southern AZ are hovering in the low to mid 30's and my furnace is working great, but propane is costly and a decent working heat pump might mitigate some of that cost.
Alan
2012 Ram 3500 DRW Crew Cab, 6.7 HO Cummins
2014 Columbus M-340RK
'69 Chevy C-10, 396BB
12-28-2016, 04:01 PM
On my thermostat it has a selection that states heat pump. Also if you pull the cover on the roof unit it will have a switching valve or reversing valve. This piece will have several small and large copper lines going to it with a coil on the end of it
12-28-2016, 04:02 PM
Heat pumps work great if the ambient temp is not too cold and you use park electricity for heat, not your propane!
