Old 10-24-2021, 11:29 AM   #1
Dometic T-stat
Our Salem has the dometic 3316410 t-stat showing E-3 (indoor temp sensor shorted). Do we replace the t-stat, overhead control, both, or what?
Thanks for any and all help.
nedlob is offline   Reply With Quote
Old 10-25-2021, 07:22 AM   #2
SeaDog's Avatar
I looked thru the manual for that stat it really doesn't say however I would think the indoor air sensor would be located at the return air and be able to replace it only. Give dometic a call and see what they have to say.
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-25-2021, 08:24 AM   #3
The indoor temp sensor on that unit should be on the board. Pull the cover off and look in the lower right corner. You should see a small device with a bulbous end.
Gotta go campin!
dometic
