09-05-2018, 07:59 PM
Door shocked me
We were camping this weekend and our bathroom gfci kept tripping and then would not reset. It wasn’t until we got home that I learned that the door was charged and it shocked my daughter and tripped the gfi. I have looked under the camper and around to see if I can find any exposed wires or wires that were not grounded. We also noticed that our awning lights would flicker and not turn on this last trip. The only thing I did was replace the fire extinguisher and mounting plate using the same screws and holes. Sooooo where do I start? 2018 Wildwood x-lite 261bhxl
09-05-2018, 08:04 PM
First thing I would do is check your source. ...where you have your rv cord plugged into
09-05-2018, 08:08 PM
It’s was plugged in to the camp site shore power 30amp and then in to my home with a regular 120 plug in but don’t run the ac
09-05-2018, 08:35 PM
Try checking the connections where the power cord enters panel.
09-05-2018, 08:42 PM
Originally Posted by vlmartinez923
We were camping this weekend and our bathroom gfci kept tripping and then would not reset. It wasnt until we got home that I learned that the door was charged and it shocked my daughter and tripped the gfi. I have looked under the camper and around to see if I can find any exposed wires or wires that were not grounded. We also noticed that our awning lights would flicker and not turn on this last trip. The only thing I did was replace the fire extinguisher and mounting plate using the same screws and holes. Sooooo where do I start?
We need a few more details;
1- Was the camper plugged into power at the campground or were you boondocking?
2- How old, make, model of the TT may help, (someone else may have the same model).
3- Are you now plugged in to power at home now?
If you're not plugged in at home, can you? Then, try to reset the GFCI & with a multimeter, test the door jamb again.
If the test checkout OK, then there most likely was a bad ground at the campground pedestal.
This may be a good time to invest in a good surge/circuit protector.
2014 Prime Time Sanibel 3250
09-05-2018, 08:56 PM
Was that fire extinguisher mounted near the door? Try taking it off ( no matter where it is located) and see if that solves the problem. It's possible that the screws came in contact with wires and created a short. (A slim possibility, but and easy check.) Get a flashlight and see what's behind those screw holes.
2015 Dynamax REV 24TB class C
09-05-2018, 09:25 PM
Ditto. I always check the last thing I changed.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
09-05-2018, 09:26 PM
Yes it is and I did take it off and still doing it
09-05-2018, 09:27 PM
2018 Wildwood x-lite 261bhxl and plugged it in at home and doing the same
09-05-2018, 09:36 PM
You've obviously got a short somewhere. The easiest to check would be disconnecting the battery, then turning off circuit breakers, fuses, etc. Might be that awning or its lights that were flickering.
Since your rig is probably under warranty, you might need to take it in for some diagnostic work.
09-05-2018, 09:45 PM
Get a piece of wire long enough to reach the door and a known good ground on the electrical system. Check the voltage from the door to the ground. If it is over 14 volts it's probably an AC problem. I suspect it is because a 12 volt will not give you a shock unless you are REALLY grounded like across the terminals of a battery with wet hands.
09-06-2018, 08:52 AM
No warranty went out in July
09-06-2018, 09:23 AM
If you can get a reading on a meter you can start turning off one breaker at a time and the 12 volt to isolate the problem. Once you know what circuit you should be able to hunt it down. First check your power at the trailer end of the power cord. Last thing to check since it will be a little more difficult would be the wiring and breaker panel.
09-06-2018, 09:28 AM
Test as mwdilday recommends above, one circuit at a time. When the GFCI trips does the short still exist, or does this cure the problem? If so then the short is downstream from the GFCI.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
09-06-2018, 09:31 AM
If you have your ground energized it could cause the GFCI to trip.
09-06-2018, 09:45 AM
Stop everything!!!
First off, STOP!!!
What you have is known as a 'hot skin' situation and is very dangerous.
There is a specific reason we have this thread listed as the very first sticky under our electrical section:
http://www.forestriverforums.com/for...-rv-89191.html
Simply because it is a very dangerous, very life threatening situation. I highly recommend you read though that thread, and all the related linked information before you do anything further. You can also reach out to forum member jmsokol. He is Mike Sokol of the No Shock Zone and is recognized as an expert in this situation:
Are "Little" Shocks OK? | No~Shock~Zone
09-06-2018, 09:56 AM
Thanks Kaadk. I was looking for a youtube video that explains all of this as well.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
09-06-2018, 10:09 AM
I had a "Hot Skin" and tracked it down to a neutral wire behind the 30 amp socket that was touching the ground terminal. Everything "worked" as there was a path back to earth ground.
What causes the danger is that with wet feet or kneeling in grass while touching the camper, you make a MUCH better return path to ground than the Neutral and Safety ground.
Recipe for disaster...
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
