Old 01-23-2018, 12:18 PM   #1
Question E450 First Oil Change
I was wondering if there was any good advice regarding doing my own oil changes on my 2017 Sunseeker, E450? I would like to get it out of storage on the next day it is not freezing cold and change the oil in my driveway. I am probably most concerned with getting the right amount of torque on the drain plug and the filter. Any special tools? I plan to gain a little elbow room by using the leveling jacks? Which oil? which filter?
JohnGaines is offline   Reply With Quote
Old 01-23-2018, 12:33 PM   #2
RedLdr1's Avatar
A couple things...
First, I would not work under a vehicle only held up by the leveling system. I'd at least use jack stands to supplement them.
The filter and oil weight recommendations are in your Ford Owners manual. But even so look at your oil fill cap to get the correct oil weight for your motor. As for brand there will be the usual "oil war" over which brand is best. I just use Ford's OEM oil and filter.
The first oil change also requires installing a few zerk grease fittings on the front suspension. The chassis is shipped with plugs in those locations. You might want to let a Ford dealer do the first oil change so those all get installed.
Other than the zerks there is nothing that requires any special tools...
Wayne and Christine
2020 Ford F-150 Lariat SuperCrew FX4, 3.5L, Max Trailer Tow Package, 7000# GVWR
RedLdr1 is offline   Reply With Quote
Old 01-23-2018, 01:37 PM   #3
Presuming you have the Triton V10 like I do, the oil filter may be attached to an oil cooler added to the base engine, and may not be the same filter specified for the base engine. I made the mistake of buying a filter per the owners manual, then found that the actual filter was different. I suggest removing the old one and taking it in for duplication or equivalent matchup with another brand (Wix makes good quality filters). Many vehicle OEM's now recommend light 5W-20 oil because they have to in order to claim slight additional fuel economy ratings. This will accelerate wear in a highly loaded engine. I use full synthetic 10W-30 from any reputable brand name, and change it myself after every major trip (usually ~5,000 mile trips).
Underdog is offline   Reply With Quote
Old 01-23-2018, 02:00 PM   #4
retireearly's Avatar
Ford changed the oil recommendation on the V-10 for recently made engines so check your fill cap before you buy, I had to return the 5w-20 oil that Autozone sold me because my cap says 5w-30. This is on a late 2016 chassis. It is an easy oil change to do with the external filter design, I didn't even need to raise the front end.
2017 Forester 2291S
2015 Honda Accord on Master Tow Dolly
retireearly is offline   Reply With Quote
Old 01-23-2018, 02:17 PM   #5
This has never applied to the V10 since it was never in a vehicle that needed to meet fuel efficiency ratings. Use what the manuals say since the people that designed the engine likely know better than you and I.
babock is offline   Reply With Quote
Old 01-23-2018, 09:58 PM   #6
5-20 motor craft think 7qts motorcraft filter 820s 5/8 wrench. Also check your generator
retired on a mountain is offline   Reply With Quote
Old 01-24-2018, 01:49 PM   #7
Happycamper
think about getting it done at a ford dealer. the cost with coupon is really comparable to what you would pay for parts alone. you don't have to worry about your particular states disposal laws. plus, electronic documentation of date and mileage saved forever means no problems down the road if a warranty situation comes up and the dealer wants proof of oil changes. just a receipt for oil and filter don't cut it.
fkovach1 is offline   Reply With Quote
Old 01-24-2018, 02:03 PM   #8
Easy oil change. Just buy quality oil of recommended viscosity.
A Ford OEM filter is really inexpensive.
You may consider replacing the drain plug with a Fumoto oil drain
valve. Makes next and subsequent oil draining much easier.
yellowwing is offline   Reply With Quote
Old 01-24-2018, 03:13 PM   #9
rvrobocop's Avatar
I am all about easier. Never considered it. No issue with the F106SX used without the ADP-106 adaptor?
Scott
2011 Sunseeker 3170DSF
2002 Honda CR-V
"Do not mistake my benevolence for weakness."
rvrobocop is offline   Reply With Quote
Old 01-24-2018, 04:15 PM   #10
My friend's Fumoto got surgically removed by a piece of truck tire. Only add if its pretty protected.
Old 01-24-2018, 04:21 PM   #11
A bit late, but plenty of room, even for us pear shaped folks, with no jacking needed. If you must, park over a dip, or put two wheels on the sidewalk/curb for the few minutes you will need.
Dp26 is offline   Reply With Quote
Old 01-24-2018, 04:27 PM   #12
I agree. Never needed to jack up a 2WD 1.2T pickup either.
I also always use a torque wrench on oil drain bolts. Takes an extra minute but especially important on aluminum or hybrid pans. They have a spec for it for a reason and most good dealers use one.
Old 01-24-2018, 06:06 PM   #13
The real PITA is our one vehicle with a disposable drain bolt gasket. I never can find a replacement, so I make one from some blank material... Tired reuse once, but the fresh syn oil found a way out.
Old 01-25-2018, 09:22 AM   #14
Wolverine 1945's Avatar
I use Mobil One 5 W 20 in our 2003 F-150 our 2011 EDGE & our 2013 E-450,,,
I get it @ Sam's when they have it,,, and Motorcraft Filters from WallyWorld !!!
I would never put 10 W 30 in a Ford engine !!!
Wolverine 1945 is offline   Reply With Quote
Old 01-25-2018, 10:23 AM   #15
Steeljag's Avatar
Mine requires the 5W 30 Click image for larger version
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 01-25-2018, 09:19 PM   #16
You didn't say whether you have gas or diesel. Makes a big difference. If you have a diesel be sure you change the fuel filters also. Also like one of the guys said, throw some stands under that thing. As for drain plug torque, make sure you start it good by hand and just snug it up good.
aquenichet is offline   Reply With Quote
Old 01-26-2018, 08:55 AM   #17
Originally Posted by Steeljag View Post
Mine requires the 5W 30 Attachment 160897
I guess things hae change since 2013 !!!
Old 01-26-2018, 09:08 AM   #18
Kenny kustom's Avatar
Ford never offered a diesel in an E450 for motorhome use.
Itís a V10 Gas.
2017 Dynamax Isata 4
Old 01-26-2018, 09:15 AM   #19
I see they have a 5cyl Diesel in the new trans van MH !!!
Old 01-26-2018, 09:59 AM   #20
Oh, my bad. Wonder why?
