Old 09-25-2020, 07:32 PM   #1
dbellue's Avatar
Entry lights
I have a 2018 Chaparral 30RLS and cannot figure out how to turn on the step light.
dbellue is offline   Reply With Quote
Old 09-26-2020, 09:11 AM   #2
SeaDog's Avatar
usually the control for the step light is on the main control panel or a switch by the entry way. If you are switching things and the light is not coming on I would check the actual light itself it may be bad.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-26-2020, 09:41 AM   #3
it may be on the light itself. turn on all switches and tap light.
Thomas ho is offline   Reply With Quote
Old 09-27-2020, 04:16 PM   #4
mikkeeh's Avatar
The inside step light should be marked on the switch inside. The outside step may be connected to the porch light switch.
mikkeeh is offline   Reply With Quote
Old 09-27-2020, 04:31 PM   #5
bubbles's Avatar
I don't have your unit but if you have electric steps are you referring to the amber light that is underneath on the steps mounting structure?
Old 10-04-2020, 12:25 PM   #6
Entry lights
On our 2018 chaparral the internal step light switch is adjacent to the hallway light switch. The outside step light is tied to the porch light switch. Both lights should be easy to replace if needed
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is online now   Reply With Quote
Old 10-16-2020, 07:42 AM   #7
I was just in changing a slide out switch on the master electric panel on my chaparral. When I was removing the slide switch I accidentally pulled a few wires out from other switches.
It made me think that perhaps you might have one wire/lug that May have become disconnected from its switch behind the panel.
light
