One other thing to check, although if you check the duct connections to the furnace you will notice this. I had similar problem with our 2018 Grey Wolf. Noticed heat coming out vents was minimal, but a lot of heat coming out of cold air intake under stove. Thought the ducts had come loose. Removed cold air intake grill, ducts were fine, but side of furnace facing inward had completely fallen off. I found 2 screws holding panel on, and reattached panel.
Good luck.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
