Old 05-15-2020, 07:57 PM   #1
Firestone ride rite air bags
Guys I need help. I just brought home my new 2020 Sunseeker 3050s. I decided to check the air pressure in the air bags because I was bouncing everywhere on the way home from the dealer. The passenger side showed 13.5 pounds. So I put 55 pounds in. The driver side read 13.2 pounds. When I tried to put air in it, it would not take it. I tried multiple times with no avail. So I went back to the passenger side to bleed that down to the same as the drivers side. I mistakenly bled it to 5 lbs. when I tried to add air that bag would not take it. I am mildly upset as you can imagine. I called the dealer and they said bring it back but it is three hours away. I am trying to find a local dealer to do the warranty work. Sure would be nice if someone has a magical solution!
keywestsoul is offline   Reply With Quote
Old 05-15-2020, 09:03 PM   #2
You will be able to air it up. Keep trying. You could even try a bicycle pump. I would settle on 50 psi for starters.
Retired Chief USN
2017 Sunseeker GTS 2800 QS
2017 Jeep Grand Cherokee toad
1985 Gulfstream Sunstream (sold)
charles l is offline   Reply With Quote
Old 05-15-2020, 10:21 PM   #3
Sometimes certain air chucks and certain Shrader valves don't play well together. The chuck pin may not be adequately depressing the valve pin. You might try a different air chuck or air pump to see if you can get air into the bags.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
air bags
