Old 11-27-2020, 06:43 AM   #1
Floor sag
I have a 2018 wildwood 28dbk. The floor right in front of the kitchen sink is sagging. It seems lower and dips right there. Wth is going on with this ???
Is this a common thing ?
John68 is offline   Reply With Quote
Old 11-27-2020, 09:56 AM   #2
I know nothing about your rig, but any noticeable sag implies the flooring plywood/particle board is not properly supported from underneath. A reasonably skilled person should be able to supplement the framing from below.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 11-27-2020, 01:04 PM   #3
Thank you.
Old 11-27-2020, 01:40 PM   #4
Could you have a water leak under the sink that's caused floor damage?
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 12-18-2020, 11:31 PM   #5
I think itís pretty common. The floor joists are too widely spaced and the floor material way too thin. When the foam between the joists gets compressed over time you get the sag. You will probably see it wherever people stand. The bathroom sink, the toilet, and near the dinette are typical.
Falconman is offline   Reply With Quote
Old 12-18-2020, 11:42 PM   #6
Thanks guys
Old 12-19-2020, 08:51 PM   #7
If you have luan floor then its typical with that floor i have 2018 wildwood heritage glen 5th wheel that is soft in front of stove and its not from a water leak. you can here the top layer of 3 strand plywood cracking when you step on it.i have some what plan to fix it it will be summer time project as i live in mine full time.
Gmoney67 is offline   Reply With Quote
Old 12-19-2020, 11:04 PM   #8
Thanks, so it's not just mine.
I have an extended warranty on my camper, will they fix that under warranty ?
Old 12-20-2020, 12:02 AM   #9
bikendan's Avatar
Don't know how we answer your question, since you provided no information on which extended warranty you have.
All I can say is look at the fine print, which is where most 3rd party extended warranties list their exclusions.
floor
