It depends on the foam material.
Styrofoam can't have any petroleum-based solvent adhesive used on it. That means that flammable roll-on contact adhesive, or spray-on adhesive like Scotch 77 is a no-no.
However, a latex-based contact cement should be no problem.
Urethane foam would be a different story.
So more info is needed before you can get a good answer.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
