03-30-2020, 05:21 AM
Ford E450 (2005 6.8 L V-10)--How many grease points?
I found and greased only four yesterday
My 2005 Ford E450 manual has no reference to grease fittings at all
Does anyone know if I might find more than 4 grease fittings?
I located 3 on left and only one on right (passenger side) tie rod end.
Am I missing any?
BTW at age 79, it's been maybe 20 or so years since I greased car fittings, but some of us remember doing this many times on '50's and '60's cars, all of which are valuable now, huh.
Thanks--Jerry
03-30-2020, 06:09 AM
My 2016 F53 chassis had 9. 5 on one side by steering gear and 4 on the other.
Jerry & Marianne
2019 Forest River Berkshire 34QS
Fort Snelling National Cemetery Rifle Squad
USS Decatur DDG-31 1971-1975
03-30-2020, 07:08 AM
Citrus County, Fl.
From the Ford Motorhome Chassis Maintenance Guide.. There are indeed 4 grease fittings on the E Series. Right tie rod end, Drag link end, Steering Gear Arm, and Left tie rod end.
The F-53 has a total of 9
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
03-30-2020, 07:20 AM
The four you mentioned are the only grease points I know of - two on the drag link and one on each tie rod end.
I can look at mine later today and confirm.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
03-30-2020, 10:18 AM
That's all, 4 on the E450.
Mine came with zerks already installed.
03-30-2020, 10:43 AM
Ford ships the chassis with plugs, not zerk fittings, in those four positions. I had to remind my local Ford dealer to install the zerks when they did my first oil change.
Wayne
2024 Sunseeker 2150SLEF / Ford E-350
03-30-2020, 11:43 AM
Citrus County, Fl.
Not having zerk fittings must be something new. My 2016 (2015 chassis) came with them installed.
99 Terry 31G
03-30-2020, 12:55 PM
Yep. I had previously thought they all came with Zerk fittings installed. However, when I took my 2019 E-450 in for a front end alignment (which Forest River paid for), the guy doing the alignment said he removed the plugs, put in Zerks, and lubed the joints.
03-30-2020, 06:28 PM
I have a 2018 E-450 Sunseeker 3010DS. So you're saying the chasis comes without the grease zerks installed and should have them installed on my next oil change? Can someone confirm just how many there should be?
Mark & Karen
and our 3 furry friends
Elkhorn, NE
2022 FR3 30DS
03-30-2020, 07:16 PM
4 up front--but what about driveshaft?
Does E450 have a grease fitting at U joint on driveshaft? I'm new and am trying to grease all fittings. BTW my Ford E450 manual mentions no grease fittings at all.
Thanks again guys
Jerry
03-30-2020, 07:58 PM
Not that I could find on mine. Searched the whole length, not even a plug.
03-31-2020, 11:38 AM
Thanks again guys
Jerry
It varies by year. I don't know what year Ford went to sealed u-joints. I'd check really closely...
Wayne
03-31-2020, 11:40 AM
Our 2018 E-450 chassis had four plugs that needed removed and zerks installed.
Wayne
03-31-2020, 12:38 PM
Thanks again guys
Jerry
Most E-450 cutaway chassis come from Ford with a 176 inch wheelbase. Except for the shorter floor plans, most class C finished motorhomes have extended wheelbases up to about 220 inches. For Forest River, I believe MorRyde, as a chassis up fitter, does the job to extend the wheelbase. In doing so, they have to extend or add sections to the drive shaft. So the u-joint type may not necessarily going to be based on what Ford uses, or what’s described in the Ford manual, but rather based on which supplier supplies drive shafts to MORryde.
05-05-2020, 05:44 AM
No zerks on my E-450 driveshaft
I have searched front to rear and found none
So I have four total NOT ON DRIVESHAFT..... all up front, as mentioned earlier (and are easy to grease by this 79 yr old laying on Harbor Freight folding mat......a wonderful thing)
Thanks guys
