Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-09-2018, 12:20 PM   #21
MillMitch's Avatar
we poured it down the toilet. I had to winterize before our last trip about 2 weeks ago and I brought 8 jugs of pink stuff with us. We dry camped (w/ electric) and poured teh pink stuff down toilet to flush. Also dumped dishwater down toilet. Gone for a week and the first time we filled the black tank.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 11-09-2018, 01:30 PM   #22
Originally Posted by Larry-NC View Post
Only works if you put "pink stuff" in the fresh water tank.
Larry
Not if you pour it out of the jug into the toilet to flush. Done this many times.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=19
Old 11-09-2018, 01:48 PM   #23
Chuck_S's Avatar
Fresh water tank and RV antifreeze should never be used in the same sentence. Certainly not in the camper!
Multiple dilutions and rinsing are really the only cure. Pink taste seems directly related to the time the pink stuff remains in contact with the tank -- or the water lines. No reason to leave it in the water lines over the winter either. Once all the water is gone neither the antifreeze nor air (in the empty water lines) will freeze. Use your compressor to blow it out.
The only real purpose of pumping the system full of antifreeze after the water is blown out is to be sure the water pump has no water in it. I doubt that takes a cup.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 11-09-2018, 02:26 PM   #24
Larry
Nope, works if you just dump it in the bowl. Duh!
2005 Forester 2901
2005 Scion XB
RacerRalph is offline   Reply With Quote
fresh water, tank, water, water tank
