My 2004 Geargetown 37 ft motor home leaks gasoline from the underside in the vacinity of the gas tank when the tank level reaches full. The gas pump does not shut off, and gas starts running out. When I stop the pump, the leak continues for a few seconds . I cannot tell exactly where it is comming from. Once the leak stops, there is no lingering gas odor after the spilled gas evaporates. This has happened at two different gas gas stations. Has this happened to anyone out there, and how was it fixed?
Make sure the nozzle is all the way into the fill. They put an "overflow" feature to prevent people from "topping off" their tanks. The pump nozzle will then shut off when full, DON'T try to top it off.
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
