Old 01-04-2021, 04:41 PM   #1
Furnace
I’m confused. I very seldom use the furnace if ever . Decided I should check it out . Makes fan noise but not very loud . Air comes out of ceiling vents not floor . Fan set on high . Floor vents temp 62. Ceiling 70 . Unit is cardinal 3875. Any thoughts, help ?
Kwralph is offline   Reply With Quote
Old 01-04-2021, 04:49 PM   #2
Always Learning
It's the fan set on high part- that turns on the blower in the A/C. The idea here is that hot air rises so it'll get sucked into the A/C and then distributed around the RV.
Change the fan to Auto:
https://learntorv.com/help-ac-comes-...heat-comes-on/
You'll then feel warm air from the floor registers.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
ependydad is online now   Reply With Quote
Old 01-04-2021, 05:30 PM   #3
Ok thanks will do when I get back
Thanks much
furnace
