Old 12-07-2017, 09:47 PM   #1
Jeff6146's Avatar
Furnace not working (split to own thread)
Edit by site team: This post and the following replies have been moved to their own topic thread, in order to help future members with similar problems.
Y’all PLEASE HELP!! It’s freezing in here and the damn furnace is not working. I’m in San Antonio in school and all last night and this morning it was working fine. I came home tonight after school and it was freezing in here. The furnace is blowing cold air. What is going on?breaker is not tripped and the fuse is good. I read what y’all had posted and mine doesn’t have a + symbol. So I figured it was the temp up button. I pressed it and waited like 2 seconds and pressed the on/off button. Readout lit up and said furn and it had zone 1. and the furnace in the belly kicked on. It ran for about (guessing) 2 min and shut off in the belly. My owners manual says something about defrost cycle(Heat Pump models only). What is that and how do I do it. I can’t follow the instructions.
Jeff6146 is offline   Reply With Quote
Old 12-07-2017, 10:18 PM   #2
Originally Posted by Jeff6146 View Post
Yíall PLEASE HELP!! Itís freezing in here and the damn furnace is not working. Iím in San Antonio in school and all last night and this morning it was working fine. I came home tonight after school and it was freezing in here. The furnace is blowing cold air. What is going on?breaker is not tripped and the fuse is good. I read what yíall had posted and mine doesnít have a + symbol. So I figured it was the temp up button. I pressed it and waited like 2 seconds and pressed the on/off button. Readout lit up and said furn and it had zone 1. and the furnace in the belly kicked on. It ran for about (guessing) 2 min and shut off in the belly. My owners manual says something about defrost cycle(Heat Pump models only). What is that and how do I do it. I canít follow the instructions.
Have you checked your propane supply?
2011 Traverse LT, 3.6L, FWD
Old 12-07-2017, 10:20 PM   #3
Jeff6146's Avatar
Itís running on electric. But yea I just filled them
Old 12-07-2017, 10:21 PM   #4
Jeff6146's Avatar
The water heater shouldnít be on the propane should it.
Old 12-07-2017, 10:25 PM   #5
Jeff6146's Avatar
I followed the instructions on zone control to set it to only one zone. The thermostat immediately did this for the two minutes and now the furnace shut off. But this is still on.
Old 12-07-2017, 10:26 PM   #6
Jeff6146's Avatar
Old 12-07-2017, 10:27 PM   #7
Jeff6146's Avatar
Should I transfer to the other tank?
Old 12-07-2017, 10:28 PM   #8
Wobbles's Avatar
I think it should. Is your propane shut off at the tanks or regulator?
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 12-07-2017, 10:29 PM   #9
There are VERY few RV furnaces that run on electric (i.e, 110VAC), unless you've had an electric heating element added to it. ALL of them need 12VDC to run their control boards.
Water heater can run on either electric (110VAC) or propane (but propane needs 12VDC for control), but if you have shore power, you should run on electric to save your propane.
Old 12-07-2017, 10:29 PM   #10
Jeff6146's Avatar
You know what, my stove was hardly lit also. Is that my dang problem. Iíve been sitting here freezing
Old 12-07-2017, 10:31 PM   #11
Wobbles's Avatar
Getting there brother...
Bob & Michelle
Old 12-07-2017, 10:34 PM   #12
Jeff6146's Avatar
How do I switch to only electric
Old 12-07-2017, 10:37 PM   #13
Scoundrel
HangDiver's Avatar
A very deep cold front passed through Texas late this afternoon and many places that never see snow are seeing it tonight. Makes me wonder if this could be another butane vs propane problem...
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 12-07-2017, 10:38 PM   #14
Under the assumption that you've somehow run out of propane AND that you've now re-filled the tank(s):
Close both LP tank valves. Re-open them VERY slowly (just a crack for say, 10 sec, then open). (If you open them quickly on a line that has run out of gas, there is a high flow valve that will close because it thinks there's a line break).
Now light your stove and make sure you've got a normal flame. This will purge the gas line of as much air as you can.
Turn your furnace OFF, then try starting it again.
Old 12-07-2017, 10:39 PM   #15
Jeff6146's Avatar
How do I switch tanks. Guys really, Iím green at this RV stuff
Old 12-07-2017, 10:40 PM   #16
Wobbles's Avatar
For your furnace, I am sure that is propane only. The stove not being fully lit makes me think that the tank valve(s) are not open all the way or your (if you have one and I bet you do) splitter (draws from both tanks or one at a time) is not pointed where is should.
The real bummer would be that you are about out of propane...
Have you recently refilled the tanks or... How long ago?
EDIT:
I think Rockford is taking you in the right direction.
Bob & Michelle
Old 12-07-2017, 10:43 PM   #17
Jeff6146's Avatar
Like 3 days ago
Old 12-07-2017, 10:45 PM   #18
Jeff6146's Avatar
But I only opened one cause I didnít want to blow myself up. Lmao. Let me take a picture of this valve I turned. Holy **** it snowedClick image for larger version
Old 12-07-2017, 10:46 PM   #19
Wobbles's Avatar
Like 3 days ago
Follow Rockfordroo's advice. Lets find out if you have propane flowing...
Bob & Michelle
Old 12-07-2017, 10:49 PM   #20
Jeff6146's Avatar
ID:	157820Click image for larger version
