09-23-2022, 12:04 AM
Always Learning
Generator exhaust under slide, need extension for Genturi
We are headed to the Balloon Fiesta next week and I keep remembering that I need to do something about my generator’s exhaust even with my battery + solar upgrades. I previously bought (and still have) my Genturi. The problem now is, the exhaust of my generator comes out under a slide out and I am not entirely sure how to attach the Genturi. It can’t go straight up.
Any recommendations for an exhaust extension that I can clamp on and then connect the Genturi to it? (Presumably also figuring out a way to support it all from the ground.)
09-23-2022, 06:49 PM
I rigged my Genturi exhaust so it would work with my portable generator on my TT's rear bumper. Problem of supporting the "stack" was as simple ( for my setup) as supporting it from rear ladder.
To support yours perhaps some custom made "s-hooks" to hook over top trim of slide??
As for exhaust, take a look at electrical EMT conduit. Might find some the same size as genset' exhaust pipe. Connect to exhaust pipe with coupler that's been slit with hacksaw so you can clamp with U-Clamps (just like a replacement muffler-).
I used the heavy duty rubber "tarp strap" type bungee cords and adjusted lengths so they supported the weight of the Genturi, not the exhaust pipe.
If you can't use hooks over top trim, I've read of some using the suction cup grippers glaziers use to handle glass panes.
Place on side, press pump piston several times, instant grip that holds LOT of weight ( and infinitely adjustable to hold exhaust stack)
09-23-2022, 07:39 PM
CCL
My solution
I have the same situation on my GT5. See picture. Used an 1 1/2" flex exhaust pipe and fashioned a bracket to offset the genturi from the slide. Works well.
Clark L
SW FL
2021 Georgetown GT5 34H5 - Jorge
09-26-2022, 04:49 PM
Always Learning
Thanks to both of you. I like the strap idea to support the Genturi.
The flex pipe is what I've been looking at:
https://www.amazon.com/gp/product/B0027J9O0O/
I really need to figure it out.. you know, we're actually boondocking today and will be until the 9th. lol
Lower 80s/upper 70s during the day but nicely in the 50s at night. Maybe I'll get away without needing the generator.
09-26-2022, 05:15 PM
hope that generator is a diesel
no way would I want a gas engine exhaust under a slide
slide seal could easily wear and allow gas in
stinky diesel would not be nice as well?
Tarpon Springs FL
2022 Salem 24RLXL
09-27-2022, 11:51 AM
Always Learning
It's gas and a very common design for gas motorhomes that have a driver's side slide across many manufacturers.
09-28-2022, 12:08 PM
Always Learning
Didn't get my parts yet and ran my generator a bit yesterday. Once I got neighbors, I decided to do the bare minimum and blow the generator exhaust towards the road. Not the prettiest setup, but this works for the moment.
09-28-2022, 04:19 PM
Just curious, if that is how they design it do they expect the customer to figure out how to safely exhaust the fumes or do they think it is safe? Does not make sense to me.
I do notice that MHs have an exhaust, usually in the front that barely sticks out past the front edge of the unit. Also always to mounted too low..
09-28-2022, 04:26 PM
Always Learning
I can’t speak for the manufacturers but given how common of a design it is, it seems that they think it’s safe. And honestly, with 150 hours of runtime + 2 extra CO detectors, I’ve only once had one of them go off (and it was an extra). It was after 6-7 hours of generator runtime at that session.
So… (shrug)
10-12-2022, 01:23 PM
Always Learning
Closing the loop on this. I ended up taking ideas presented here and elsewhere and came up with the following:
I ended up finding 1 1/2” flexible exhaust that was a nice & easy slip fit over the exhaust pipe.
At the Genturi end, I ended up having to cut the flexible pipe and open it up slightly. An exhaust clamp worked well to hold it together.
Flexible exhaust: https://www.amazon.com/dp/B0027J9O0O
Exhaust clamp: https://www.amazon.com/dp/B0019I64F2
Suction cups: https://www.amazon.com/dp/B08N13T8X2
10-12-2022, 02:06 PM
Nice job.
As a potential future neighbor, I thank you. Exhaust fumes from a rig next to us at the Balloon Festival made me sick because the exhaust exited their rig near ground level and traveled to the door of our rig.
Their rig had no exhaust enter their rig, but we did. Going in and out the door of our rig was not a pleasant experience. Had to keep the door shut all the time.
2015 Dynamax REV 24TB class C
10-12-2022, 02:12 PM
Great work Doug!
So the flex pipe is stiff enough it keeps the upper end of the Genturi (near the roof line) from laying back against the side of the R/V or the slide wall?
10-12-2022, 02:35 PM
Always Learning
Originally Posted by Reverse_snowbird
Nice job.
My neighbor started without anything and we had to keep that side of our windows closed. He must have realized and loosened the screws for the exhaust to rotate it towards the front of his rig where it wasn't blasting us any longer.
Originally Posted by 5picker
Great work Doug!
Yeah, the exhaust was stiff that it didn't just collapse/redirect without intention. It wasn't hard to shape, but it did hold its shape.
And then it straightens back out for fairly easy storage.
