Old 03-09-2020, 03:31 AM   #1
Geo pro 19BH-outlets only work off inverter
My outlets only work when the Inverter is on.
So Iíve read about all the issues with gfci outlets going out and having to reset the breaker fuse on the inverter. I will try first thing in the am. However, is that the case with my issues?
My outlets only work when the inverter is on.
Yes, I have shorepower. The microwave works and the ac works. Iím so confused.
Any ideas?
Caliche is offline   Reply With Quote
Old 03-09-2020, 08:47 AM   #2
That is the way it is wired, shore power go's through the inverter and inturn the inverter fan runs all the time and is noisy.
I moved my inverter to the floor and built a sound deading box over it leaving the front and back open for air flow.
Here is a pick in the stock location. I did not take any pics after I moved it but I could if needed.
The green wire is the trailer feed from the inverter and the purple is the AC feed to inverter.
Toyota FJ cruiser
Flagstaff E-Pro 16BHG
Discovery is offline   Reply With Quote
geo pro, inverter
