Old 05-21-2020, 06:28 PM   #1
Georgetown GT5 Fresh Water Tank
I cannot trust my electronic water tank level gauge that never seems to go over 2/3 full. When filling the fresh water tank, how do I know when it’s full? I cannot see the tank and I don’t want to overfill it’s. Is there an overfill line somewhere where I cannot do any damage by completely filling? Any guidance is much appreciated.
Call911 is offline   Reply With Quote
Old 05-21-2020, 06:50 PM   #2
bubbles's Avatar
Look for a stream of water out the bottom of the rig. The vent for the tank is also the full indicator. If you look under the rig you will see an open tube sticking out and when it spits water the tank is full.
Old 05-21-2020, 06:51 PM   #3
NXR
NXR's Avatar
I add water until the overflow behind the passenger side duals starts dripping water.
I also use a water flow meter on the city water line to add a known amount of water if needed.
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 05-21-2020, 08:48 PM   #4
Thanks for the info! Happy Camping!
Old 05-22-2020, 02:44 PM   #5
Dennis King's Avatar
When I over fil mine it runs out and there is a screen over the overflow tube. But mine for some reason will siphon half or more out of the tank if if I overfill it. I don’t know how to get the drain from spewing water even 10 minutes or more after I shut off filling hose. Any suggestions?
Dennis King is offline   Reply With Quote
Old 05-22-2020, 03:01 PM   #6
rk06382's Avatar
See quote below:
FIX for "Fresh water tank self draining?"
Originally Posted by rk06382 View Post
From the FR3 subforum | Fresh water tank self draining?
My solution:
Fresh water tank self draining? #27
I have reposted this to share with Forest River owners that don't watch the FR3 subforum.
Robert
2018 FR3 28DS | Boondock 90% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 05-22-2020, 04:50 PM   #7
Some techies seem to like compicating things
As several simple minded folks have suggested, just drill an 1/8" hole in the overflow line at its highest point where it comes out of the tank. Done.
Sandy B is offline   Reply With Quote
Old 05-22-2020, 05:00 PM   #8
Dennis King and others . . .
I have a GT5 and had the same issue with the fresh water tank siphoning after water started running out the overflow.
Problem solved . . . eliminate the siphon action.
I removed the tape-screen from the bottom of the overflow (save it for later use).
I then inserted a lenght of 1/4" vinyl tubine (Home Depot) into the overflow, far enough that it reached the TOP of the first bend in the overflow line (or maybe just a couple of inches further), leaving about 1" of tubing extending below the bottom of the overflow line. I use the same tape-screen to tape the 1/4" vinly tubing in place and keeping the rest of the overflow tube screened as well. Water MUST be allowed to run out both the OEM overflow tube and the 1/4" tube. The 1/4" vinyl tubing will break the siphon.
How did I know the tubing was at the TOP of the first bend? I removed the cover inside the basement bin that allowed me to see the overflow tube, and the 1/4" tube moving inside it. I could also tell by resistance when pushing the 1/4" tubing into the overflow tube that I had reached the TOP of the first bend.
When filling the fresh water tank, I still have some water run out indicating the tank is more than full, but it runs out only for a minute or less, leaving me with a completely full tank.
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
fresh water, georgetown, tank, water, water tank
