Old 01-12-2022, 05:17 PM   #1
Glue for flooring?
I have a 2020 Salem and the vinyl flooring was damaged. It is now peeling up and it appears like there is no glue holding it down at all. What kind of glue should I use to repair it and hold it down?
DeanHensler is offline   Reply With Quote
Old 01-12-2022, 06:35 PM   #2
You need to know the type of backing on the vinyl before you use any glue. If you use the wrong type of glue, it could cause "plasticizer migration" which could result in stains and or irreparable damage to the vinyl.
They have been utilizing a perimeter glue process on many vinyl floors these days. Much faster to install, especially when they are working on the flat floor with no walls built yet.
Marc in sunny California
2013 Crusader 260 RLD
2012 RAM 2500 Laramie CTD and 4:10
mmartin_tdc is offline   Reply With Quote
Old 01-12-2022, 07:40 PM   #3
D W
D W's Avatar
Had a small tear in floor. I cut out the tear and removed a piece of loose vinyl from under the kitchen cabinet to patch where the tear was cut out. Used this to glue the patch to the floor:
https://www.walmart.com/ip/RH-Adhesi...lear/210928995
The blended the edges of the patch to the floor vinyl with this:
https://www.amazon.com/Performix-61Z...59160739&psc=1
Worked great. Looks like a short plank in the floor.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 01-12-2022, 07:49 PM   #4
buy a can of ,,,3M SUPER 90 SPRAY ADHESIVE. follow directions on can. you can , not let it set up it will dry and adhere perfect ,just put some weight on it for a few hours.
Thomas ho is offline   Reply With Quote
Old 01-28-2022, 12:37 AM   #5
Gorilla super glue non expanding.
U can waste ur money figuring out the correct glue but i install flooring and It might be easier to super glue the edges down. Go get a big bottle and bam
Khtie is offline   Reply With Quote
Old 01-28-2022, 11:16 AM   #6
Just want to make sure that glue doesn't bleed some color through the vinyl
Old 01-28-2022, 11:17 AM   #7
Got any pictures of the finished product?
Old 01-28-2022, 11:18 AM   #8
I can tell they just used glue around the parameter of mine and it must be the wrong kind because there is a yellowing color coming through in multiple area's around the parameter.
Old 01-28-2022, 11:25 AM   #9
With the supply chain issues, even flooring adhesives have been affected. I know our purchases that used to ship in a day or so, now can be delayed one or two weeks. Manufacturers can't get the chemicals they need to make it. It ships on trucks from SoCal, so not a port/container issue, just a raw material issue.
Old 01-28-2022, 11:54 AM   #10
My unit is a 2020 and I think it was actually manufactured in Oct 2019, so it was built before the pandemic. In my opinion forest river builds an extremely cheap and low quality camper. I've had so many issues with mine... I guess the good news is I bought it in May 2020 before the prices of these things skyrocketed. I can't imagine how I would feel if I paid $40k for this thing...
floor, flooring
