Old 10-11-2018, 09:47 PM   #41
Mr. Dan's Avatar
Originally Posted by Azdigs View Post
Read the post right before mine
OK, if you had quoted it, I would have known to which post you referred.
Old 10-11-2018, 10:17 PM   #42
Denver To Yuma In 90 Days
I've skipped over most of the posts, so forgive me if this has already been said...
I had the exact same problem.
Too hot upstairs in the bedroom and bathroom and no heat down to the living room.
Turns out that the heating ducts were full of sawdust and other gunk from the factory and clogged the furnace ducts!
Dealership hat to cut two gigantor holes in the bottom (coroplast) of my 5'ver to clean it all out.
JohnD10 is offline   Reply With Quote
Old 10-11-2018, 11:01 PM   #43
Oh, I cut a small section so I could take a peek, and found what exactly is the problem. I even snagged a picture of it. If you zoom in on the picture, you can see that the whole duct is torn, and not just a quick fix.
Rachael is offline   Reply With Quote
Old 10-11-2018, 11:05 PM   #44
I don’t know how to set up the page, but, if someone else does I’m in.
He was talking about a Go Fund Me page. But I found out what the problem is. I will be able to fix it myself, but will be a little tricky.
Old 10-12-2018, 04:42 AM   #45
nomad297's Avatar
I think the hard part is over. You found the problem! I opened a high-resolution version of your picture and I can’t see the tear, but at least you know where it is. The easy part is fixing it.
Good job.
Bruce
Old 10-12-2018, 11:01 AM   #46
Duct tape is your friend... gorilla tape too... good job at finding the
issue... and you did it all by yourself.. well mostly by yourself...
mrfikser is offline   Reply With Quote
Old 10-12-2018, 11:28 AM   #47
I'm glad I read through this entire post.
Great job tackling this yourself. You've learned stuff for yourself and you've gained some confidence in your abilities.
Gotta go campin!
Old 10-12-2018, 02:55 PM   #48
+1.
Pick up a roll of aluminum tape. It sticks like crazy and won’t be affected by the heat.
Rick & Paula Birch
2017 Cedar Creek 33ik
2015 Lance 2295
2018 GMC 2500 Denali
Nights camped 2018=60
Azdigs is offline   Reply With Quote
Old 10-12-2018, 03:50 PM   #49
Kanadian Kamper
kenandterry's Avatar
Yup....for this repair I would use the aluminum tape they sell for sealing duct work in heating ducts of houses. It’s very flexible and won’t be affected by heat. Much easier to position and surround the tear in the duct work.
It’s really cheap so don’t be afraid to layer it on the tear.
https://www.homedepot.com/p/Reflecti...T210/100318556
Ken and Terry
kenandterry is offline   Reply With Quote
Old 10-12-2018, 06:01 PM   #50
Temporary Fix!
So as it turns out, both of those ducts were ripped. I am not sure how it passed inspeaction, or that they miss ed d it all together at camping world, but I'm rather miffed. They had specifically told me they would go over everything to e sure oh t would all be in working order, which it wasn't.
I'm posting some pictures of the before and after. This is just a temporary fix until Next week, when I am going to attempt to put all new ducts in. Got 3 things of 4in x 25ft ducts. That should be more than enough, and I can always salvage the old stuff if need be.
ID:	189007   Click image for larger version
ID:	189008   Click image for larger version
ID:	189009   Click image for larger version
ID:	189010   Click image for larger version
Old 10-12-2018, 06:08 PM   #51
Mr. Dan's Avatar
Good for you! You've earned some major stripes!!
Old 10-12-2018, 06:20 PM   #52
Witch Doctor's Avatar
That will be a lot of work for you. What you can do is just buy some 4" pipe at Lowe's, galvanised it comes in 4' sections and then just put a section in where it's ripped and tape it up. Nothing wrong in your approach but this would be easier. If your going to strap it up to hold it, use 4" wide cloth straps, they sell 1" metal but do not use it , it will choke off the duct, not wide enough. You have came along way in a week, and by your hard work you will be a lot more comfortable this winter, "WHAT A WOMEN" YOU go get them girl.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-12-2018, 07:56 PM   #53
Glad you found that...
I also had two of those...they were the easy fix!
It was later that we found the real problem...the sawdust in the duct work!
Don't be surprised if this doesn't totally fix your problem!
Old 10-12-2018, 08:46 PM   #54
RichL
Rich70's Avatar
Sounds silly but have you removed the vent cover to see if the tube is clear? Sometimes they run the hose so far and then cut a hole in the wall/styrofoam to the vent cover.
Rich70 is offline   Reply With Quote
Old 10-13-2018, 05:59 AM   #55
I already purchased 3 packs of the 4in by 25ft ducts like what is already in there. By the look of it, they arent really hanging up for the most part, only one section I could see it, other than that, its ran through some other areas, but not attached to the underside of the floor as well.
I figure if I just fully replace those 2 lines, I can shorten them so there is no sagging, and also see if there are any other holes/tears in the process. I'm going to have to cut a huge section, and drop it to the ground in order to do it all at one time, then tape it up
It looks like there may be a leak some where also. There was a puddle of water, and the coroplast was white (the coroplast itself is black), and where it was wet, was slimy. I think it may be coming from the grey water tank, but that one I leave open, so no clue.
I'll probably do a live FB video, and put a link for it there, so everyone can see the mess I'm having to deal with, and fix.
Old 10-13-2018, 07:38 AM   #56
Hope you can set it up on FB. after 25 years in the HVAC business, let me tell you first that flex duct is pure garbage I dreaded the day they came out with that junk back in the 80's. The biggest problem I have seen with that junk is the factory doesn't strap it up which causes it to sag. if its sag's you will lose atleast 25% of air flow. They like running it over wires and pipes instead, which causes it to be crushed. You are correct make the runs as straight as you can , you can also staple cloth straps up to the sub floor to support it. At best the air flow from these furnaces are not great, so anything that you can do will help each time you bend that junk you are adding to your problem. Its a shame how these factory's put this stuff in. I'm glad you got it under control...
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-13-2018, 08:08 AM   #57
A32Deuce's Avatar
I thought those flexible lines were for high speed fans, not the low speed in an RV!
A32Deuce is offline   Reply With Quote
Old 10-13-2018, 08:15 AM   #58
Now that is funny...pure garbage
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-13-2018, 08:17 AM   #59
You have the same in your M/H, just they are all 2"
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-13-2018, 08:20 AM   #60
A 2" duct can produce like 45 cfm at a 1/2 static, and people wounded why there units don't heat. 45 cfm is like a elephant fart.
Coachmen M/H
Concord
2018 / 300 DSC
trailer
