That really depends on your personal preference. If it was just me, it would be about 65 degrees. For my wife and mother-in-law that would be about 72 degrees minimum. What do you keep your house thermostat set at?
Now, what I have done is replaced the mechanical thermostat for my LP gas furnace that had the old lever slide control with this thermostat:
https://www.amazon.com/gp/product/B00QW2WXRS
There is also a horizontal version that is a bit cheaper. Besides being able to see a digital number for temperature and setting, I like this thermostat because it has an adjustable range. Most thermostats work on +/- 1 degree spread. I found that my furnace was cycling on and off too much when it was cold and at night. So I set this thermostat for a 3 degree range. If it is set at 68 degrees, the furnace comes on at 65 degrees, and turns off at 69 degrees. To me, that keeps me comfortable and also prevents the furnace from cycling on and off excessively.
