This summer I hooked up two satellite receivers "Bedroom/Living room". Now I want to reconnect our antenna but not sure ware I removed them from. Cables that is. Would anyone know ware to put the connections for using the antenna ? If anyone has the color coding and locations that they go it would be awesome. Thanks. Chris.
I am assuming " Our Antenna" is the crank up one on top your rig. Your TV cable plugs into a female RF jack that is located on a panel close to the TV that normally contains two of these jacks One on top of this panel is to provide service from an outside the rig source, one on bottom has a slider switch and a led light that lights up when the switch is moved to "ON". Plug your TV cable into the lower on with the switch and then crank up the Antenna for reception.
Ours is an 832ikbs. We have an orange coax, a tan coax, and a black coax connected to the antenna amplifier. I need to know where these cables connect to the amplifier.
We connected two of them together to put sat signal from outside to both living room and bedroom. Now I have forgot how to put it all back to factory normal.
