Old 06-13-2021, 07:33 AM   #1
Undercover Poe's Avatar
Help No Heat!!
In my 2018 Acadia LT29!!!???? I tried to flip on the heat last night and nothing!! I have propane. I set my Dometec t stat to heat, head the over head interlock but couldnít not get the blower motor to fire. I took apart the heater cover and pressed the reset switch a million times. Any thoughts where to start?Click image for larger version
Undercover Poe is offline   Reply With Quote
Old 06-13-2021, 07:40 AM   #2
Retired Army MSG!
lazyjj's Avatar
I do not or never have had this model, however, RV furnaces are 12V. I would recommend looking at your fuse panel on the 12V side and see if possible there is a blown fuse. I assume all lights and other 12v accessories are working.
lazyjj is offline   Reply With Quote
Old 06-13-2021, 07:47 AM   #3
All the lights and all the 12V works. Just the furnace wonít fire / Blow. AC pumps cold. Click image for larger version
Old 06-13-2021, 08:05 AM   #4
Retired Army MSG!
lazyjj's Avatar
I recommend going to the converter and checking the fuse for furnace. There should be several auto type fuses that control 12v accessories. Most have led lights. If you see a red led lit up on that panel that normally represents a blown fuse. Also, are you turning the temp on the thermostat up enough that it is more than the ambient temp in your rig to allow the furnace to start?
Old 06-13-2021, 08:49 AM   #5
Handyman
Just off the cuff here. I assume you have an electric ignitor. If you can hear the ignitor "popping", you're probably not getting gas. If not "popping", you're probably not getting power.
2016 Salem Cruise Lite 253RLXL
2013 F-150 XLT 5.0 Crew Cab
2009 F-150 King Ranch 5.4 Crew Cab
tfmdgm is offline   Reply With Quote
Old 06-13-2021, 08:53 AM   #6
Mr. Dan's Avatar
The blower motor has to spin fast enough to set the sail switch before the furnace attempts an ignition sequence. The OP's blower isn't spinning assuming "couldnít not get the blower motor to fire" means 'could not'.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 56; Booked = 52
Old 06-13-2021, 11:42 AM   #7
There are no red lights on in my panel there are no burnt out fuses. Iím familiar with the function of the snail switch. As I have had the snail switch get stuck and I have not been able to get the furnace to light but that is not the case this time this time I canít even get the fan motor blower to turn
Old 06-13-2021, 11:57 AM   #8
Mr. Dan's Avatar
Itís SAIL switch if youíre doing a search.
Old 06-13-2021, 12:37 PM   #9
OK but thatís not the problem. I canít get the blower motor in it even start
Old 06-13-2021, 05:40 PM   #10
Did you confirm power at the furnace?
Did you try to rotate the blower motor wheel? Use caution if it starts up! I recommend you turn thermostat off during the blower wheel test to see if it spins or is locked up. Bypass thermostat test/is the thermostat showing it is call for heat?
Lucky you, you got a site in Acadia
Good Luck
mfMcFroggierPod is offline   Reply With Quote
Old 06-13-2021, 05:53 PM   #11
Just Tryin' to Help
cboss's Avatar
Or try to spin it with a pencil, just not your finger!
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1044
cboss is offline   Reply With Quote
Old 06-14-2021, 05:42 AM   #12
Good Luck
When you say ďconform powerĒ are you suggesting I test for 12V at the blower motor leads? And then yeah let me check that and spin the motor with a stick. Good place to start. Thank you.
Old 06-14-2021, 06:45 AM   #13
dotsonjc
Friend of mine had similar issue, and found out his battery was weak, just didn't have enough juice to support the furnace igniting and running the motor. Just offering up as something to check out.
Current:
2011 Expedition XLT
2018 Wildwood X-Lite 282QBXL
Past:
2012 Coachman Freedom Express 22DSX
dotsonjc is offline   Reply With Quote
Old 06-14-2021, 08:19 AM   #14
Correct x2
and also 10.5+ vdc minimum req
Old 06-14-2021, 08:53 AM   #15
Flybob's Avatar
If no 12V at the blower, I would pull the fuse for the furnace and measure it. The red lights do not always indicate properly.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-14-2021, 10:23 AM   #16
Correct,
Sometimes a fuse looks good even though it is bad. Continuity check or voltage passing through the fuse.
Ohms Law
W/V=A
V lower = Higher Amp draw
Good Luck, hopefully it is just a bad fuse and not a bad motor or circuit board...
Old 06-17-2021, 07:39 PM   #17
I pulled the fuses checked him switch them around, all the fuses are good. I pulled off the cover again with my voltmeter check for 12 V on every wet red wire back there and nothing
Old 06-17-2021, 09:29 PM   #18
There needs to be some source of 12vdc feeding the furnace. The thermostat is only a remote signal sending switch. If the fuses are good it is possible a wire has broken/dis-connected/poor connection. Can you trace the wires from the circuit box? Check all of the connections.
Old 06-17-2021, 10:04 PM   #19
Have you tested the blower motor directly with 12vdc?
Old 06-18-2021, 05:34 AM   #20
Iím embarrassed to say I canít even find the power leads at the motor inside the furnace box
