Old 05-29-2017, 11:17 AM   #1
Cestash's Avatar
Help please
I'm having connection issues between the truck(16 f150) and trailer (Cherokee 274dbh). When hooking up through the 7pin it will show connected but will show disconnected randomly, I lose the electric brakes but not the turn signals/break lights. Any thoughts or suggestions?
Cestash is offline   Reply With Quote
Old 05-29-2017, 11:58 AM   #2
Mddle of the Rd Extremist
MeepMeep's Avatar
Sounds like you may have a bad ground.....easiest way to find out is to connect a wire between the truck chassis and the trailer chassis. If the problem goes away, you know where to look
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 05-29-2017, 12:49 PM   #3
It could be a bad plug or loose wire connection on either trailer or truck. Check them.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 05-29-2017, 01:28 PM   #4
Scoundrel
HangDiver's Avatar
I had a very similar problem and it turned out to be a bad connection at truck/trailer plug. I used a flathead screw driver and an abrasive cloth to clean the contacts in the female plug and that fixed it.
Good Luck
HangDiver is offline   Reply With Quote
Old 05-31-2017, 10:13 AM   #5
Tim Coltrain's Avatar
Wiring
Due to water and rain these plugs have a tendency to go out. Replace and rewire every three years. My problem solved when following these instructions.
Tim In NC
Tim & Rita Coltrain
2012 Chevrolet 2500 Duramax Crew Cab, Allison Tranny Has now been replaced by a NEW 2018 LP5 Duramax 2500 Allison Tranny.
XLR Thunderbolt 2016
Tim Coltrain is offline   Reply With Quote
Old 06-05-2017, 01:07 PM   #6
Close friend had the same problem with his '15 F-150. After the dealer sending him a brand new 7 pin trailer connection, the issue still persisted. Turns out, there was a bad ground. After finding the bad ground on his trailer, the problem has not come back since. Chase your grounds, both truck side, and trailer side. Hope this helps, good luck!
Cheers, Cody
'18 Rockwood Signature Ultra Lite 8299BS
'14 Salem Cruise Lite 261BHXL (SOLD)
Tow Rig: 2014 RAM 2500 Laramie Longhorn 6.7L Diesel
CodyPereira is offline   Reply With Quote
Old 06-10-2017, 09:59 PM   #7
I use this CRC 11 oz. QD Electronic Cleaner-05103 - The Home Depot
on stuff that is is exposed to water. If you can get it Super CorrA is the best I think it made by Lektro-tech.
Fly YX is offline   Reply With Quote
