Old 09-19-2021, 04:25 PM   #1
help with locating leak!!!!
I have salem village 42fk. it just down poured here and i have a leak in my bedroom but it is dry in my loft.
wondering where i should start looking?
william v is offline   Reply With Quote
Old 09-19-2021, 06:54 PM   #2
Librarianocnj's Avatar
You can always find a service center that can do a Sealtech test. They use air pressure to find the leaks.
Librarianocnj is offline   Reply With Quote
Old 09-19-2021, 07:54 PM   #3
Herk7769's Avatar
A walk on the roof might be quite enlightening.
ANY gaps or deep cracks in the DICOR sealant must be fixed.
If the leak is below the air conditioner, the foam seal could be the culprit.
An improperly torqued foam seal can leak over time and once there is a "path" between the seal and the roof, it will always leak in the rain from then on. Replacing the seal is your only option for a permanent repair.
The yellow torque tabs should "just" kiss the roof material at all 4 places for a proper installation. If they are tightened past that, the foam seal will not make even contact with the roof.
HAM CALLSIGN - KC3FFW
