Old 04-21-2021, 05:37 PM   #1
High Tire Pressure
My Rockwood Mini Lite tire pressure calls for 65 PSI which is what I inflated them too. These tires are relatively new. While driving the tire pressure on my TST Monitor goes up to 76 PSI and 100 degrees temp and the alarm goes off with a high pressure warning. I understand that the tire pressure will rise while driving but I'm not sure what is normal.
Piper76 is offline   Reply With Quote
Old 04-21-2021, 05:47 PM   #2
rsdata's Avatar
Depending on speed, outside temps, whether the sun is shining on the tire sides... that is normal range...
You should set the TST for a little higher pressure and temp alarm so it does not go off on you in that normal range.
The most critical thing with tires is that no ONE tire goes noticeably outside of the range of the other comparable tires... a warmer or a lower pressure than the average of the other tires is a sign something is going on.
Back before TPMS, you would just go around and feel the tire temp with your hands, both on the sidewall and tread to fell if any one tire was warmer than the others... of course keeping in mind that one side may be in the sun which will raise the temp even further than those in the shade.
2014 Shamrock 183
rsdata is online now   Reply With Quote
Old 04-21-2021, 05:50 PM   #3
Thanks, that’s kind of what I thought.
Old 04-21-2021, 06:01 PM   #4
Virginian's Avatar
I have seen, somewhere, the recommendation to set the TPMS alarms for 20% high and 10% low. I have mine set for that, 50 psi tires, 60 psi high pressure alarm, and 45 psi low pressure alarm. I have seen them around 58 psi on the highway, but never reached 60.
I left my high temperature alarm at the factory setting of 148 degrees, based on online research. This has been working well for me.
2019 Wolf Pup 16FQ - bought new 3/2020
2013 F150 5.0 STX SCab 4x4 SB/3.55 rear/tow pkg./36 gal. tank/1695 Payload/7350 GVWR
Andersen Hitch
Virginian is offline   Reply With Quote
Old 04-21-2021, 06:17 PM   #5
I had exact same issue, glad you asked this. I think i changed mine to 80, might go a little higher even when i get to some hot Florida roads.
TT - 2021 Rockwood 2608BS
TV - 2020 F-250 XLT 4WD SRW 6.2L gas
mac1_131 is offline   Reply With Quote
Old 04-22-2021, 01:52 PM   #6
Always Learning
I wouldn't willy-nilly just start picking values.
TST recommends 20-25% for the high pressure over the cold pressure. Here's a calculator to help pick values:
TPMS Configuration
And then, I don't get too alarmed if all of my tires are tracking similarly. It's when I have 1 tire that's acting up vs. the other 3 or 5 that I start to investigate. Here's an article with information about using your TPMS:
https://learntorv.com/how-to-use-your-tpms/
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
pressure, tire
