Old 10-20-2019, 07:24 PM   #1
How do I remove tv from mount. If you cant see behind it?
I have a 2013 Cedar Creek Silverback and I want to change out the hdmi cord from the factory jensen tv but I am unable to see behind it to see how it is mounted or even fit my hand between the entertainment center and the tv to change out the hdmi cord. It is very tight? Help would be greatly appreciated...
chupa999 is offline   Reply With Quote
Old 10-20-2019, 07:48 PM   #2
RandK-M's Avatar
I don't have a Cedar reek, but if it's similar to my mount the TV lifts off the mount by pushing it straight up. It's tight though and I have to slap the bottom of the TV. The mount is Kind of like this picture:
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
RandK-M is online now   Reply With Quote
Old 10-20-2019, 07:57 PM   #3
dbledan's Avatar
Mine is different but same premise. Lift up on it. You may want to make sure there is not an arm to swing out. Mine was stiff but there. Click image for larger version
dbledan is online now   Reply With Quote
Old 10-20-2019, 09:05 PM   #4
RandK-M's Avatar
Originally Posted by dbledan View Post
Mine is different but same premise. Lift up on it. You may want to make sure there is not an arm to swing out. Mine was stiff but there. Attachment 217718
Good point about the swing arm. Mine has it also, but has a very strong magnet that holds it against the wall for travel. The magnet is strong enough that I sometimes think I'm gonna break the TV when pulling it away from the wall. I grab the TV at the top and bottom in the center and give it a good yank to break the magnet free. If it's closed, there's no way I could get to the connections in the back like the original poster mentioned.
Ray
2017 Rockwood 2109S
Ram 1500
US Navy Veteran
Old 10-21-2019, 12:41 PM   #5
Tom48's Avatar
My non Cedar Creek model factory bracket has a spring loaded catch at bottom with a inch sized pull ring then lift tv off
Tom48
In Sunny So Cal /w
2004 SD F250 now BULLET PROOFED
2017 Sandstorm 250 TH, with
8 wheel TST TPMS and
The Hot Air Balloon RESTLESS
Tom48 is offline   Reply With Quote
Old 10-21-2019, 02:43 PM   #6
HI!
We have a 2019 Chaparral 5th wheel and had the same problem with the mount. We needed 3 people, two on the latches behind the TV with THIN arms to release the latches on each side. We needed a mirror at the bottom to see the mechanisms and a light shining from the top. Once the latches were released, two people had to lift the 50" TV off the mount. Now we are replacing it with an articulating mount from Costco, which will allow the TV to be moved out and tilted. BUT we must also attach a belt or cords on each sidewall so the TV won't move while we are travelling. Also we won't be able to pull the TV out too far, lest we pull the wall with it!!
ross0547 is offline   Reply With Quote
Old 10-21-2019, 02:56 PM   #7
Retired Member
rmwmiata's Avatar
I used a small mirror and flashlight to see how mine is secured.
Pam and Murry Wilbanks
2018 SIERRA 377 FLIK
2018 Ram Laramie 3500 DRW
rmwmiata is offline   Reply With Quote
Old 10-21-2019, 04:46 PM   #8
I donít remember itís official name, but I carry a rope type camera that works with my phone. Canít remember how many times Iíve used it to anylize problems on my 5er. It would solve not being able to see behind your television.
Bnrc73
2010 Montana 3400RL
Worthington MN
Bnrc73 is offline   Reply With Quote
Old 10-21-2019, 05:37 PM   #9
Borescope or Endoscope
Often called borescope or endoscope
Larry
Larry-NC is offline   Reply With Quote
Old 10-21-2019, 05:39 PM   #10
Trailer Park Supervisor
NJKris's Avatar
Generally lift up then out. If you can see top of bracket, make sure there isn't a set screw or anything holding in place, but the post #2 pic is probably the type of bracket.
NJKris is online now   Reply With Quote
Old 10-21-2019, 06:24 PM   #11
kirk37r's Avatar
We have A 2013 Cedar Creek 38FL. The bedroom TV is mounted with A Thule TV Mount. It is a round bar type. It clicks into a mounting pad on the bottom, and releases with a white trigger assembly at the top of the bar. Really handy as there is a mount outside for moving it when you want. Sure wish thule didn't discontinue them as I would really like to have another.
The main TV raises and lowers into a cabinet behind the fireplace. That is mounted onto 2 cross bars and is removed by loosening 4 10mm bolts and lifting off the bars.
Not sure if the SilverBack uses the same thing though.
Kirk, Carol& Nicholas (Grandson)
2013 Cedar Creek 38FL, RV Cams rearview cam
2012 Ram 3500 DRW
CAUTION behind this truck is A contagious disease!!!
Its called Camping!!!
kirk37r is offline   Reply With Quote
Old 10-21-2019, 08:18 PM   #12
SailorSam20500's Avatar
Just a thought, do you have a mounting bracket on the outside of your trailer? Mine does. The TV should have the same mounting mechanism....
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 10-21-2019, 09:30 PM   #13
bedubya's Avatar
Ask your dealer service dept. Most TVs are dealer installed options.
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
Days Camped: 2017-39, 2018-61, 2019-64
bedubya is offline   Reply With Quote
Old 10-21-2019, 11:46 PM   #14
I have a 2017 Cedar Creek Silverback and the living room TV is removed by pushing two spring (flat spring) loaded buttons located behind the lower center of the TV. They are on the mount and are about 2" apart. Push them both up as far as you can and pull the bottom of the TV out (toward you) and the top of the TV should drop down and clear the top of the bracket. My tech writing is a little rusty but I hope this helps.
Grumpy7159 is offline   Reply With Quote
mount
