05-21-2013, 09:02 AM
#21
And Herk, if you look at the bracket that the rear jack assembly is bolted to, you would see that it is welded ON TOP of the frame flange. If they had welded it underneath, the load would just push under the main frame, a very strong configuration. But by welding it on top. the load is being carried by a few very poor welds.
Some days I just shake my head at the guys who run the assembly of these units.
My bet is that they do it that way just because it is easier to weld that way. Their welders probably aren't very good at welding upside down.
05-21-2013, 11:16 AM
#22
After looking them over pretty closely this am, I've decided to just let them go and if they collapse for some reason or other, I'll repair them and reinforce where necessary. The whole assy, IMO is pretty flimsy and too light even for just stabilizing. Sure glad we don't have kids jumping around.
05-21-2013, 01:41 PM
#23
First attempt to fix....
Ok ... here is my first attempt with some wood blocks and a jack.
its about 90% there ... i need a large C clamp to bend the middle in alittle more.
and then do alittle welding.
2013 Lacrosse 318bhs
2010 Toyota Tundra Crew max 5.7 flex fuel / Installed airlift ultimate 5000 air bags and smart lift automatic leveling system.
Yamaha EF2000iS 2000 Watt Inverter Generators
Minooka, IL.
05-21-2013, 01:58 PM
#24
The manual is pretty clear they are for "light stabilizing" only. Attempting to "jack up" the frame will result in failure.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-21-2013, 02:03 PM
#25
One of these days when I get energetic, I might just pull the whole unit down and see what can be done to change it over to a medium-heavy duty stabilizing unit.
05-21-2013, 02:19 PM
#26
Checca, try either square tube or a pair of angle iron lengths bolted inside the leg. You may need to cut or drill a hole to allow for the existing bolt for the braces. I like 1/4" thickness for either the tube or angle. This should allow for some pounding into shape as well as reinforcement.
05-21-2013, 02:23 PM
#27
great suggestion ... i will try that.
Minooka, IL.
05-22-2013, 06:40 AM
#28
Home Debit (depot!) sells short lengths of angle iron.
Over priced but convenient.
05-22-2013, 07:08 AM
#29
Originally Posted by KyDan
Google BAL jacks and see what you get.
I just did. The type you have come in pairs for around $85.
Donno if you can get just one cheaper or not.
Try a local dealer for a single one.
They are a simple bolt on replacement so you can do this or a
friendly neighbor with a socket wrench can do it and save labor cost
as well as a trip to the dealer.
Good Luck!
OP shows (Lippert Elect.stabilizers) ,not Bal jacks? Are the Parts the same? Youroo!!
05-22-2013, 07:30 AM
#30
Probably not! I didn't realize they were electric.
Mine are electric also-- I use a battery powered electric drill to operate them
Peace!
Dan & Rita D
05-30-2013, 04:00 PM
#31
Here is the final fix ... bent straight, welded and painted.
doesn't look to bad and stronger than before.
Minooka, IL.
05-30-2013, 04:13 PM
#32
Looks good. Good job!
Fred & Teresa
2005 Coachmen Encore Sportscoach
2005 Harley Road King
2002 EZGO Golf Cart
05-30-2013, 04:15 PM
#33
Good job and saved a lot of $$$
Fonzie
05-30-2013, 04:29 PM
#34
Good job. Seeing yours, I just figured out how I am going to reinforce mine before I bend them. I am going to get some 2-1/2 x 2-1/2 x 1/8" sq. tubing and weld it to the bottom of the legs because you can't put anything inside the legs.
05-30-2013, 04:44 PM
#35
talking it over with my welder, we were thinking all that is needed is a good three passes were they didn't weld. If you look close, they weld about 1 1/2" and then empty space for 3". Just by filling in those voids you would greatly add to the reinforcement.
But we also voted against it ... he was sure its better to overload a leg then break the screw drive ... as that is were all the weight is carried after deployment.
I'm happy with the way it turned out and isn't that hard to fix if I screw-up again.
Minooka, IL.
05-30-2013, 05:01 PM
#36
On mine, the weight when deployed is transferred from the legs to the trunion and from the trunion to the mounting C tube it slides in. I will no doubt reinforce the full length of the mounting tube also as I did on my 831RLSS.
06-04-2013, 02:05 PM
#37
Just removed the stabilizer jacks from my 5er and they are extremely flimsy. Measured the material thickness of the legs and it is only 0.075" thick, which is just a little over 1/16" (0.063"). the whole assy is made out of this thin material. I will definitely be reinforcing both legs with some 2-1/2" x 2-1/2" x 1/8" tubing that I will cut one side off to get me a "C" channel about 2" deep x 2-1/2" wide and taper it at the bottom. Will also reinforce the upper channel that mounts to the frame that the leg assembly, screw & motor slide in.
These things are extremely light weight and in my opinion the legs should be positioned as straight up and down as possible as the bending strength is practically non-existent on an angle of 45° or less for any stabilizing. Should be criminal to sell these things as stabilizers. Wouldn't even make good ditch fill or a boat anchor.
06-04-2013, 03:49 PM
#38
Decided to split the 2-1/2" x 1/8" square tubing and ended up with 2-1/2" x 1-1/4" C and tapered the last 5". Ready to grind the paint off the leg and skip weld the "C" to the leg, bead blast, paint and start on the other leg.
06-04-2013, 04:58 PM
#39
nice
Minooka, IL.
06-04-2013, 05:01 PM
#40
Nice job OldCoot. I'll be by next week to get mines done! ha ha ha
Fred & Teresa
2002 EZGO Golf Cart
