Get under the sink and push up on the hose. This will help distinguish whether the hose below the faucet is tangled on something, or the hose is jammed in the faucet tube. I've never seen one jammed in the tube.
There is a weight (cast zinc, usually) that is clamped or snapped around the hose to make it retract. It should be on the hose, as low as it can get and still apply gravity retraction force.
If some goofy assembler put it on the hose right below the faucet it will cause the problem you describe. Unscrew/unsnap it, slide it down as low as you can, and re-screw/re-snap it closed. You may need a small straight-blade screwdriver to unsnap it.
Not to be xenophobic, these trailers are assembled by Amishmen. They may not have plumbing in their homes, just a pump, so they may have misassembled it. If that's what the issue is, could you post a picture?
Larry
