Old 10-26-2020, 01:53 PM   #1
I screwed up (forgot to open drains)
we closed up in the rain on Columbus day abd I can't get back on property till May. I realize I forgot to drain the lower level drains....what am I in for next sprng?
wings011 is offline   Reply With Quote
Old 10-26-2020, 02:01 PM   #2
bikendan's Avatar
Cracked water lines would be the biggest worry.
Old 10-26-2020, 02:01 PM   #3
I see your profile says Connecticut... What process did you use to "close up"?
Sustained temps below freezing will certainly wreak havoc on water left in piping.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 10-26-2020, 02:28 PM   #4
By passed wster heater and pumped in anti freeze till it came out if all faucets..toilet and showers. Thats it..dkbe it 4 years now but I 4got 1 step this time..trsiker in the Berkshires
Old 10-26-2020, 09:31 PM   #5
Might be worth paying somebody at an RV dealership or nearby campground a few bucks to go out to the unit and turn those low point drains.
Rich Phillips
richp is offline   Reply With Quote
Old 10-26-2020, 11:51 PM   #6
If you pumped RV antifreeze into the plumbing, it's possible that the antifreeze will mix with the water in the low point drains because they are all part of one system. It might be enough to protect them from freezing. Did you drain the fresh water tank?
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 10-27-2020, 12:16 AM   #7
Yes
Old 10-31-2020, 06:24 AM   #8
Seasoned Camper-MH newbie
HaroldPE's Avatar
Where is the unit? Open up low point drains and drain out the water
- HaroldPE
HaroldPE is offline   Reply With Quote
Old 10-31-2020, 10:40 AM   #9
Its on a private co-op camp...we own the site but it's gated and no entry until May of next year....it has a sealed under belly but I know I am screwed. IN the Berkshires of Mass.
Old 10-31-2020, 12:55 PM   #10
You're not definitely *screwed*. Like Snowbird said, it could survive by mixing in. Low point drains are relatively easy replacement if it is a problem.
You'd be at less risk if someone could get back there and open the drains for you as RichP suggested.
Not sure if this helps, but at our seasonal site, we're allowed to park outside and walk / ride a bike back to our site...maybe you can get back there without a vehicle.
Good luck.
Skip12 is offline   Reply With Quote
Old 10-31-2020, 01:37 PM   #11
Might be worth a shot..ty....
Old 10-31-2020, 01:42 PM   #12
Did you empty the water heater?
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 10-31-2020, 02:10 PM   #13
D W
D W's Avatar
Wow, letting it sit for six months with no eyes on it? For me, that would be unacceptable. Too many things can go wrong during the winter, and left unchecked would be detrimental to the RV.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 10-31-2020, 02:27 PM   #14
If you flushed with antifreeze, there is likely some mixing in the drain tubes. As long as there is some antifreeze present, any freezing will just produce slush rather than solid ice, and expansion will just ooze it through the lines rather than expanding a local area. Don't worry about it, just relax and enjoy the winter.
Underdog is offline   Reply With Quote
Old 10-31-2020, 03:11 PM   #15
You must have the option of keeping yours at your house in the winter. Mine goes to our fairgrounds for the winter and once I drop it off I donít see it again until I pick it up in the spring.
phipps33 is offline   Reply With Quote
Old 10-31-2020, 03:18 PM   #16
After years of reading posts about different ways to winterize, I have come to the conclusion there are four types of winterization processes. 1) Do nothing 2) Blow out lines with air. 3) Run anti-freeze through the lines until the water is replaced with anti-freeze. 4) Do both 2 and 3.
Question to the ones who only run anti-freeze through the lines. Do you normally open the low point drain after filling with anti-freeze? I would think not or you run the risk of having dried residue remain in the lines. If that is the case and the ones who normally only fill with anti-freeze do not have an issue, then the OP should be fine.
OP - I think you stated the fresh water tank was drained. I am not sure if you said you ran anti-freeze through the lines or not. If you did you will be fine. Don't ruin your next six months worrying about it. If you find out in April something went wrong... Fix it and move on. Most likely it would only be the exterior lines that gets damaged. The difficult things like toilet valves and faucets will be fine.
Looking forward to the spring to hear how you worried about nothing.
tkarper14 is offline   Reply With Quote
Old 10-31-2020, 04:00 PM   #17
Scoundrel
HangDiver's Avatar
One year I winterized in Colorado with antifreeze and forgot to open the low point drains. No problems. Maybe I was lucky.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 10-31-2020, 04:04 PM   #18
U.S.ArmyVeteran's Avatar
My small contribution.
The "war department" keeps telling me to use a check list! For setting up and breaking down the camp site. For loading the trailer and TV.
Now if she sees this.............another check list for winterizing ..... ughh.
Shhhhhhhhh
U.S.ArmyVeteran is offline   Reply With Quote
Old 10-31-2020, 04:20 PM   #19
Old Camping Squid
Eagle-751's Avatar
I live in Northeastern Ohio, I blow the lines out with air and use the water pump to push antifreeze through the lines, I have never, not even ones, ever opened the low point lines. I know where they are, but haven't touched them. If they would happen to freeze and bust, it's outside and a quick cheap easy fix. Wings011, don't sweat it, it should be just fine. Like Underdog said, it should not be able to freeze solid.
Larry Collins { PM }
2006 F150 Supercab 5.4 Flex Fuel
2017 H-D FLHTK Ultra Limited
EZgo TXT and ClubCar Precedent golf carts
2009 Forest River Salem 30QBSS
U.S. Navy Veteran
Eagle-751 is offline   Reply With Quote
Old 10-31-2020, 05:28 PM   #20
D W
D W's Avatar
I do, but even if I did store at a lot I'd still check it every two weeks for snow on the roof, theft/vandalism and vermin infestation.
2016 Salem 27RKSS
drain
