Old 02-06-2018, 11:27 AM   #41
Wolverine 1945's Avatar
I have used WD40 before,,, but with sub 0 temps sometimes ether is the only way I can get my old tractor started,,, sprayed in the carbs,,, not in the cylinders !!!
This after shining a heat lamp on the engine for a couple of hours !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-05-2018, 11:58 AM   #42
Fulltime family RVer
Welp, I ended up having a buddy give me a hand with these on Saturday.
The one generator started up on the 3rd pull. Apparently that was NOT the one I tried!
The other generator, he had to remove the carb and clean it out. Started up after than and ran fine.
Old 03-06-2018, 07:51 PM   #43
Who Dares, Wins
doc73's Avatar
Get the blue marine stabil and start putting it in your gas cans. I have used it in all the fuel I put in all my small engines for the last 10 years. Mower starts up every season (even though it sits with "old gas" in it) and the genis are always second pull.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 03-06-2018, 08:32 PM   #44
Sounds good.
Old 03-07-2018, 10:09 AM   #45
Seafoam works well also !!!
Just bought 6 cans last week,,, Buy 3 Get $6 off !!!
Coupon online,,, may have ended on March 1st ????????
Old 03-07-2018, 10:28 AM   #46
It's OK- space is at a premium for me, so I'd only have 1 can at a time any way.
Old 03-07-2018, 10:42 AM   #47
I have 8 cans @ this time,,,
when that is gone I will be looking @ the price of the Gallon cans !!!
Old 03-07-2018, 01:17 PM   #48
NMWildcat's Avatar
Maybe you should use some StaBil in that seafoam to keep it good until you can use it
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 03-07-2018, 01:20 PM   #49
Funny Man Wildcat !!!
Old 03-07-2018, 01:32 PM   #50
Who Dares, Wins
doc73's Avatar
Tough crowd
2015 ChevyHD D-Max
Old 03-07-2018, 01:43 PM   #51
Just a quick blurb from the GoldEagle web site, manufacturer of Sta-Bil products... Sta-Bil 360 Performance and Sta-Bil 360 Marine, protects for 12 months where the Sta-Bil Storage protects for 24 months.
MYTH #3: “ALL STA-BIL PRODUCTS ARE THE SAME, JUST DIFFERENT COLORS.”
Nope. Each product is specially designed to address and prevent a unique set of problems.
STA-BIL Storage fuel stabilizer keeps fuel fresh for extended periods – up to 24 months.
STA-BIL 360° PERFORMANCE protects against ethanol-related damage and provides a boost in performance and mileage economy if used at every fill-up.
And our STA-BIL°360 MARINE fuel additive protects and helps engines that perform in the damaging, water-laden environment marine equipment faces every day.
Both STA-BIL 360° Formulas will keep fuel fresh up to 12 months and provide protection to the entire fuel system – above and below the fuel line. So in the end, it all depends on what you would like to focus on -prolonged longevity, power/fuel economy or condensation management.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 03-07-2018, 01:46 PM   #52
Novice Travel Trailer Guy
benchmarks's Avatar
X2. Seafoam is magic.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
Old 03-07-2018, 01:47 PM   #53
Who Dares, Wins
doc73's Avatar
Thanks I will look into the normal stabil.
I always used the marine because it is good for the ethanol and it came in a larger container... Now its been a few years since I looked at Stabil so maybe the 360 is now the same size and price. Got more bang for the buck from the marine in the genis and mowers.
2015 ChevyHD D-Max
Old 03-07-2018, 01:53 PM   #54
I believe for our Generators we need the BLUE Sta-bil !!!
I am not looking to keep fuel for 24 months !!!
Just thru the winter !!! Seafoam all year in my small engines !!!
Old 03-07-2018, 01:54 PM   #55
Who Dares, Wins
doc73's Avatar
Well. That was my other reasoning.. The geni sits in the rain.
2015 ChevyHD D-Max
Old 03-07-2018, 01:58 PM   #56
The fuel sys in an OWAN generator is very fragile !!!
Carburetor & Fuel Pump !!!
Old 03-07-2018, 02:09 PM   #57
So is it the naptha, pale oil or isopropyl alcohol that makes it magic?
babock is offline   Reply With Quote
Old 03-14-2018, 09:37 AM   #58
Mechanic in a bottle works wonders
loyda is offline   Reply With Quote
Old 03-14-2018, 10:16 AM   #59
I have been using Seafoam for years,,, I see no reason to change !!!
I had a Push Mower a few years back when I took it out of the shead in the spring,,, it would start but not stay running,,, I poured a couple of extra ounces of Seafoam in the gas tank,,, after 5 or 6 more attempts to start it,,, it took off,,,
been running every since !!!
Old 03-14-2018, 10:47 AM   #60
I'm glad I don't have these problems. I just go to my local station and by Non-ethanol fuel. Gotta love Florida.
