Old 03-15-2018, 08:20 AM   #61
Wolverine 1945's Avatar
Originally Posted by cavie View Post
I'm glad I don't have these problems. I just go to my local station and by Non-ethanol fuel. Gotta love Florida.
Costly ???
Wolverine 1945 is offline   Reply With Quote
Old 03-15-2018, 08:38 AM   #62
Star*Tron! It is BLUE too! When I have a Gas Engine issue because of "Fuel" in any of my Gas powered tools that sometime sit for Months with Fuel in them that has been Treated with "Star*Tron",I will Post it here! I have been using "Star*Tron for several years now,No Fuel issues! Youroo!!
Old 03-15-2018, 09:00 AM   #63
Originally Posted by Wolverine 1945 View Post
Costly ???
Yes, it is considerably more. Probably more than 50 cents/gallon. Ethanol fuel attacks the fuel lines and other components as-well-as absorbing moister into the gas in small engines. Though the newer outboards have ethanol proof fuel systems and will run on ethanol/gas, non-ethanol gas is still recommended.
We are able to buy non-ethanol gas in both Wisconsin and Florida. It is worth the difference in cost to know you will have less problems. At least some Michigan stations should carry non-ethanol gas, especially in boating/water recreational areas.
PenJoe is offline   Reply With Quote
Old 03-15-2018, 09:04 AM   #64
Costly ???
Yes, about $.50 more but well worth it as little as I use in the small motors that I have. Don't put it in the cars and truck.
Old 03-15-2018, 09:18 AM   #65
Our Silverado is designed to run on E85. We have tried it in Wisconsin, but the MPG goes south. With lower gas prices now, it's not worth the "savings" because there really is no savings. It does seem to burn clean though.
Old 03-15-2018, 09:45 AM   #66
I have heard it is available here near or @ Boat Dealers !!!
Old 03-15-2018, 07:50 PM   #67
If you don’t use a lot of gas, you can buy 100% fuel at Lowe’s or Home Depot.
carlsbad is offline   Reply With Quote
Old 03-16-2018, 10:11 AM   #68
For Sure ???
Old 03-16-2018, 11:33 AM   #69
I've had my 2000 Honda's since 2009 and only use 89 octane right out of the pump, as recommended by Honda. I treat every tank of fuel with Star-tron. I treat and fill the tanks for winter storage.
NEVER HAD AN ISSUE.
grayfox is online now   Reply With Quote
Old 03-16-2018, 11:44 AM   #70
NEVER HAD AN ISSUE.
Does your Honda have a fuel shut-off valve ???
Old 03-16-2018, 01:32 PM   #71
NMWildcat's Avatar
Mine don't. But don't need one since I treat my fuel .
Scott and Liz - Southern NM
Old 03-16-2018, 01:48 PM   #72
Georgia Rally Coordinator
aceinspp's Avatar
Same here in GA. Lot of stations now carring it and I use for small engines and also use the staybil when I store. Every now and then add some sea foam. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49
Old 03-16-2018, 02:12 PM   #73
Short answer, I don't know??
Old 03-16-2018, 02:39 PM   #74
For Sure ???
Yep.
Quart cans.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 03-16-2018, 03:02 PM   #75
The local small engine lawnmower shop is making a living on ethanol.
They advise the use of Shell premium in the mowers. No ethanol in most of Ohio in that gas. Has worked for me since I Switched.
Marinas all have no ethanol gas in most places.
tomkatb is offline   Reply With Quote
Old 03-17-2018, 07:35 AM   #76
We will just keep buying gas @ Sam's,,,
sometimes it is like 30 cents cheaper than the others !!!
And treating small engines gas with 1/2 oz per gallon every time !!!
Old 03-19-2018, 10:21 PM   #77
Around here the premium paid for no ethanol can be as high as $1.25/gal.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 03-19-2018, 11:22 PM   #78
BuzzWolfAR's Avatar
But it is in quart cans at $28 a gallon. Also have premix 40:1 or 50:1 for about the same price.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
BuzzWolfAR is offline   Reply With Quote
Old 03-20-2018, 10:25 AM   #79
CRAZY !!! $$$$$
When a oz of Stabil or Seafoam will work just as well !!!
Old 03-20-2018, 12:33 PM   #80
Always used ethanol fuel in all my engines. Never an issue and never added any snake oil. My friend is a chemical engineer for Chevron. He says the issues are completely overblown.
Yes the ethanol sbsors water but unless you get to the point where it reaches saturation and you get phase separation, you won't have an issue.
babock is offline   Reply With Quote
