Old 03-26-2018, 10:08 PM   #121
NMWildcat's Avatar
Originally Posted by babock View Post
But you still need a fuel shut off if you have those if the tank is mounted above the carb.
Disagree. My two 11 year old Honda EU2000is have never been drained, or run out of fuel. I just use Stabil. Easy.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 03-26-2018, 10:14 PM   #122
I drain the bowl using the set screw. It takes just a second.
carlsbad is offline   Reply With Quote
Old 03-26-2018, 10:19 PM   #123
NMWildcat's Avatar
I've never seen the need to
Old 03-27-2018, 01:18 AM   #124
When you turn your Honda EU2000is generator off, it does turn the fuel off. It just doesn't run the carb dry.
babock is offline   Reply With Quote
Old 03-27-2018, 08:26 AM   #125
NMWildcat's Avatar
And?
Old 03-27-2018, 08:49 AM   #126
And?
You disagreed to my statement that you need to have a fuel shut off valve. Your generators do have one.
Old 03-27-2018, 08:51 AM   #127
Wolverine 1945's Avatar
Originally Posted by wahoonc View Post
Yup comes in quart cans. We use it at work on all of our small gas powered engines. Eliminates the ethanol issues.
Aaron
I am guessing using a little Seafoam is cheaper than paying $24 for a gallon of ethanol free gas ???
Wolverine 1945 is offline   Reply With Quote
Old 03-27-2018, 09:01 AM   #128
NMWildcat's Avatar
Yes, there is a fuel flow shutoff that is tied to the ignition shutoff. Still don't know what your statement has to do with the discussion of whether to run the carb dry of fuel or not.
Old 03-27-2018, 09:29 AM   #129
LOL....look at my post #119 that you disagreed with. I said nothing about running carb dry.
Old 03-27-2018, 09:40 AM   #130
NMWildcat's Avatar
Guess I'm still trying to figure out why you needed to inform us that there is a fuel shutoff valve. You could of said they have a carry handle or that martians you have seen are green, and been just as informative. I (incorrectly) assumed you were talking about a fuel shutoff in relation to the drain the carb discussion.
Guess you were just sharing your Google knowledge to share. Thanks!
