08-07-2020, 09:25 PM
Interior Mold issue Forest river wildwood
as the title says im having a mold issue on wall where shower is located , ive attached pictures and am looking on the best way to tackle this issue , im currently letting affected beams soak in bleach, im thinking only way to cure this is knock out and replace affectes beams , order and cut out sections of wall replacement then go crazy with sealant. For anyone wondering i was cleaning the bathroom and peeked behind a plastic door trim and saw the whole bottom 2 inches was moldy, i removed door along with the trim and ended up pulling the wall off. 2018 forest river wildwood
08-07-2020, 09:54 PM
A 2018 ? WOW....that's the best I can come up with.
08-07-2020, 09:57 PM
Yes im just as shocked, definitely not waterproofed enough around shower/bathroom.
08-08-2020, 02:12 PM
Update on mold remediation
trying to fix the mold without going nuclear, removed bottom portion of walls with multi tool saw, cleaned and treated the wood currently waiting for it to dry, ended up removing tub and front frame , fan on it and vent/fan open
08-08-2020, 02:20 PM
Did you find where the water leak came from?
2015 Dynamax REV 24TB class C
08-08-2020, 02:34 PM
Its definitely from shower, there was a corner where i can confidently say when the misses was getting out of shower was running from bathroom to back bunk via small hallway. I dont blame forest river because tt was never designed with full time use in mind , but im going to make some "upgrades" to hopefully prevent this from happening again.
08-09-2020, 03:14 PM
I might think about painting that interior wood with Wood Hardner. I would think that would stiffen the wood and keep it from soaking in any additional dampness that might present itself.
https://www.homedepot.com/p/Varathan...0229/305626727
2014 Shamrock 183
08-09-2020, 06:27 PM
Originally Posted by rsdata
That is exactly what I was going to recommend. It will penetrate the wood and encapsulate the mould spores so it will no longer be a living organism.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
08-13-2020, 03:00 PM
Model Number?
2019 Heritage Glen 282RK
2014 F-150 Screw 4x4 3.5EB
