Old 10-13-2024, 01:13 PM   #1
Gen
Leak at fender weld under black tank flush
We just got our IBEX and we were flushing the black tank and water started dripping from under fender. Any ideas what is on and how to fix it??
Gen is offline   Reply With Quote
Old 10-14-2024, 07:32 AM   #2
Any water inside? The pipe path starts at the fitting outside, goes through an anti-siphon valve (usually in a cabinet just inside), then down to the tank.
There's a bunch that you can's see but a leak anywhere could just be finding the fender as the exit.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is offline   Reply With Quote
Old 10-14-2024, 07:45 AM   #3
Gen
We just looked and it was some water under sink in bathroom. Fittings were loose. We tightened them hope this works. If it does not would the flush valve be bad?
Old 10-14-2024, 05:37 PM   #4
I would look at the valve during the next tank flush. They do go bad.
2013 Ford F150
Old 10-18-2024, 06:38 PM   #5
You would be surprised how water leaks can travel in a trailer!
Be sure to use a water regulator.
2018 Tracer 255RB
Mokurt is offline   Reply With Quote
black, black tank, black tank flush, flush, leak, tank
