Old 07-15-2020, 04:48 PM   #1
Leak under awning
Salem Cruise Lite 201BH, Solera power awning had a leak up where the awning in attached to the camper while awningwas fully deployed and angled down. Water was not pooling and water was coming off each gutter extension.Had water dripping down the siding (under the awning) in two spots, nothing inside that I can see/detect. Looked at roof line where edge of roof meets gutter/awning but all looks good. Any suggestions?
Kmack319 is offline   Reply With Quote
Old 07-15-2020, 05:07 PM   #2
Flybob's Avatar
There are usually a small screw in the awning track at each end to keep the awning from sliding out. This allows water to get in the track which will then run out. Also there are sometimes seams in the track that will leak. Hard to rectify. If you angle the RV slightly the water will run out of the low end.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-15-2020, 07:31 PM   #3
shubert's Avatar
Thanks for the hint Flybob. Got the same issue. Will look into.
shubert is offline   Reply With Quote
Old 07-16-2020, 06:02 AM   #4
Mch5jdm's Avatar
Has anyone ever run a bead of silicone to seal it?
Let’s go camping!
Mch5jdm is offline   Reply With Quote
Old 07-16-2020, 06:52 AM   #5
I see the the screw, there is only one. Would you suggest I remove it, fill screw hole w/sealant, then replace screw?
Old 07-16-2020, 06:56 AM   #6
KyDan's Avatar
My awning drips right over the door.... I've looked and can't really see anything to do about it.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 07-16-2020, 07:27 AM   #7
Flybob's Avatar
The Screw lets the water enter the awning slide track then it drips out the low point in the track.
TST Tire Monitors
2 100W solar panels
Old 07-16-2020, 07:58 AM   #8
Usually Confused Member
emm-dee's Avatar
A lot of awnings (all brands) are know for two trouble spots. The most common is leaking where the fabric is sewn together. The fabrics doesn’t leak but the sewing thread does. The absolute best product to fix the issue is HH-66. Just “paint” it over the threads (both sides) and leaks are gone fo a couple of years, or more. It’s available sailrite.com (they use it on their products). Lippert and Carefree both told me it has no adverse effects on the fabrics.
The other is mainly for long awnings where the track has to be installed in sections. Leaking can occur at the joint and is easily fixed with a light application of Lexel sealant.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 07-16-2020, 08:35 AM   #9
SRN
Had the same problem with water dripping down the side of the trailer from under the awning. Discovered several of the awning track mounting screws had loosened. I just tightened each screw back down, took care of the leaks. Might try that before getting out the sealer or ?
SRN is offline   Reply With Quote
Old 07-17-2020, 07:16 AM   #10
Just washed the roof and really soaked/pooled water on the closed awning. It appears that water it working its way directly into the awning channel right around the awning bead that slides into channel. There are spots that are not as tight as others. The screw that keeps the awning bead in the channel is well under the awning and does not protrude out the top. There are no seams in the gutter track either. I might try some flexible sealant along the channel/ awning in a small section to see if that does anything.
awning, leak
