Old 05-22-2022, 02:43 PM   #1
Leaking Maxxair vent
Had to start a new thread about my TT bathroom vent fan leak.
Ok found the problem with my leaking maxxair bathroom fan. Two rubber blocks were missing, which allowed water straight into the TT through the cover clips. I think I'll salvage this and reuse it in the bedroom.
Question what would you all suggest as a permanent seal, I was thinking JB weld or a two-part epoxy? I'll use straws to allow for a channel to be made in the epoxy to still use the cover clips.
I would appreciate any suggestions.
Thx
ID:	273745   Click image for larger version
2020 Rockwood Mini lite 2506s
2019 Ram 2500 Bighorn
vestup is offline   Reply With Quote
Old 05-23-2022, 06:10 PM   #2
Not sure what I'm looking at, but shouldn't there be some putty type sealant there? Something like this https://www.amazon.com/dp/B07V366FCM...xpY2s9dHJ1ZQ==
You might also want to get a vent cover cover. That keeps most of the rain away from the vent and protects it from the sun deteriorating it.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-24-2022, 06:06 AM   #3
continued leak
The first set of pics is the cleaned up under side of the maxxair vent, there use to be rubber plugs in the holes, butyl tape and dicor on top, all failed and allowed water into the TT. I have everything exposed and wish to permanently close off the holes. I will than apply butyl tape and replace the dicor. I am seeking the best way or product to close off the holes. Adding sealant is only temporary and will eventually fail. I am researching JB weld, Marine Tex and other epoxies.
Thankyou
Old 05-24-2022, 11:53 AM   #4
Most of us just stick some silicon or dicor down those holes from the top so we don't need to pull anything apart.
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is offline   Reply With Quote
Old 05-24-2022, 02:09 PM   #5
Understood
I here ya, I went down the silicone, and dicor route for two seasons, it would be fine then after a storm I’d have a very wet bathroom floor. Pulse it started to migrate on top of the ceiling toward the rear bedroom, that’s when I said no more. Pulled it and installed the low profile version. This one I plan on reusing once I’m confident it’s permanent sealed.
Old 05-24-2022, 03:27 PM   #6
I wouldn't use silicone. You can't get anything to stick to that stuff.
There's a YouTube video where the guy uses butyl tape, then screws it on and runs lap sealant along the edge and on top of each of the screws. It looks a lot like what's on our fans. (just ignore the ads)
The vent cover cover that you show in your picture is also a good idea.
Old 05-24-2022, 04:14 PM   #7
My silicone comment was solely for sealing the holes in the standoffs on the base from the exterior while up on the roof. Not related to mounting the fan/cover itself.
2021 Flagstaff 21DS
Old 05-25-2022, 12:13 PM   #8
Thankyou
The clips that the red arrow are pointing to are notorious for leaking on Mini Lites. Put some ProFlex in the hole of those clips and it solves the problem.
2019S Mod Thread
https://www.forestriverforums.com/fo...ad-184896.html
2020 Rockwood Mini Lite 2109S
2021 Nissan Titan XD Platinum Reserve
01tundra is offline   Reply With Quote
Old 05-28-2022, 11:35 AM   #9
I went with JB water weld, taped them up to contain the epoxy and ran a wire through so I could use the clips again. Dried pretty hard, looks completely sealed.
ID:	274064   Click image for larger version
ID:	274065   Click image for larger version
leak, maxxair, vent
