Old 08-05-2020, 10:54 AM   #1
Jy1
Led awning lights not working
After 3 years my led awning lights have stopped working on my 2017 wildwood 27dbk. I noticed one time when I turned them on they flashed for a second but did not come on. Iíve checked all fuses including the 2 amp in-line fuse That is in the wall under the access at the rear of the camper. I found one forum that pointed at the RGBW controller in the wall under the same access cover. I replaced this. (About $7 on Amazon). Still doesnít work. I started checking voltage and have about 13 volts to the controller but only about 7 volts out. Faulty controller? Other ideas? Also, I believe this controller is just for the remote. Anyone just bypassed this so the lights just work from the switch?
Jy1 is offline   Reply With Quote
Old 08-12-2020, 12:31 AM   #2
Do you also have a remote that you can use to turn those lights on? If so, I have found that my camper sometimes gets “confused” and won’t let me turn those lights on or off, but it eventually works
retire057 is offline   Reply With Quote
awning, led, light
