We have a 2020 Sierra 321RL that has had numerous issues in our 1st year of ownership. It is now 14 months old and having hydraulic jack & slide issues. Got home from camping, extended front jacks & unhitched from truck. Then pushed auto level button and it said grounding jacks, nothing happened & after more time, said timed out. Went to manual mode & lowered the back jacks which ended up picking tires off the ground on one side. In manual mode, tried to retract front jacks to manually level. Would not retract & also tried back jacks & they wouldn't retract either. After trying numerous things recommended by the service dept where we purchased RV, such as turning control panel off & try again. Disconnected power, battery, waited 10 minutes, reconnected, still nothing. Even tried connecting jumper cables from truck to RV battery, still nothing! We were told to try all of this by service dept.
After searching google, forums & you tube videos, my husband opened valve for front jacks & used drill to manually retract the front jacks so we could get it hooked back up to our truck. Then had to do the same to raise the other 4 rear jacks. Now that it was fairly level, I opened the slides in kitchen/living area to remove food, etc. since we will most likely have to bring in to dealer on Monday. Then the slides would not retract. So, my husband again located the correct valve for the hydraulics to slide, used drill and manually got them back in.
Looking for suggestions or knowledge of what the cause is of this issue? I've read about possible in line fuse, relay switch???
I'm sure hoping it can be figured out. Any help is appreciated. Thanks!
