Originally Posted by adrienbaker
Wanted to update this thread in case somebody experiences this problem in the future.
I took the fan back apart and plugged it back in but I realized that was just the power from the circuit board to the motor.
I pulled the 12v fuse powering the fans and plugged it back in and it started working like normal again.
Adrien
Just about anything today controlled by a "circuit board" responds to the "when in doubt REBOOT method".
Sometimes solid state devices get confused and lock into a particular mode which is not what YOU want. Power down, restart, and the circuit resets.
A note, just turning off and back on immediately may not work. Better to totally disconnect power (like removing fuse), let all components that might be storing power bleed down, then restart.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
