09-03-2012, 04:05 PM
Mineral deposits on Mirrors
Does anyone have a tip for removing water mineral deposits from our side mirrors? The air conditioner condensation dripped off the roof when it was parked on an unlevel surface in our driveway. I tried white vinegar and when that didn't work, I tried Comet spray cleaner (non-abrasive). I would appreciate any tips you can offer. Thank you.
Larry, Paula & Bailey the Adorable Red Toy Poodle
09-03-2012, 04:11 PM
I have great success with Cerama Bryte used to clean a glass top stove and a fine scotch brite pad. Be careful with the mirrors as too much rubbing will remove the mirror finish. Works great on windshields and glass windows.
09-03-2012, 04:20 PM
[QUOTE=1jeb289;246858]I have great success with Cerama Bryte used to clean a glass top stove and a fine scotch brite pad. Be careful with the mirrors as too much rubbing will remove the mirror finish. Works great on windshields and glass windows.[/QUOTE
Thank you. That sounds like a great idea!!
09-03-2012, 05:17 PM
Would not use scoth-brite or steel wool on ony surface you don't want scratches on! Doesn't matter what surface you are using it on. It WILL scratch!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
09-03-2012, 05:30 PM
like a job for "MURATIC ACID", read the lable and use carefully, but it should work, removes everything from rust to crust on plumbing things.---- if it doesn't work diluted-- try it straight but have water ready to wash it off. I had streaks on my truck windows from water run-off and this work on it.
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
09-03-2012, 05:32 PM
I respectfully disagree. Yes, steel wool will definitely scratch which I did not recommend. The very fine "no scratch" scotch brite will not scratch glass. I know for myself as I used this method to remove hard water deposits on our 2 cars. You have to be careful on the mirrors as too much rubbing will rub through the finish.
09-03-2012, 05:48 PM
how about CLR....available in hardware stores and home centers.
CLR*Calcium Lime Rust Cleaner | Walgreens
2008 rockwood signature ultra lite 8315SS[SIGPIC]
09-03-2012, 05:56 PM
As the owner of a polishing company for 30+yrs serving the automotive, medical, consumer, and aeronautical industries all over the world, I still would not use a scotch-brite pad, regardless if it says it's "non abrasive". The scratches may not be visible to most, but I work on a micro level and scratches exist. A soft cotton cloth and stove top cleaner should remove any build up on a glass mirror.
09-03-2012, 07:58 PM
I will try the soft cloth and stove top cleaner. We haven't even take our maiden voyage yet, so I don't want to harm our new "baby" in any way! Thanks for all the ideas!
09-13-2012, 08:19 PM
Just thought I'd follow up on this. I tried the glass stove top cleaner with a damp paper towel and the mineral deposits came right off without scratching the mirrors. Thanks for the idea. Love how you are all so helpful!!!
