Old 06-05-2017, 09:51 AM   #1
Moisture Barrier ripped
We just returned to Wisconsin from Florida and when we got back I noticed that the moisture barrier between the frame and the bottom of the trailer had come loose and I was dragging part of it. I have attached some pictures so hopefully that helps to explain what I am talking about.
I am guessing I would need to do something to protect the wood that is now exposed on the bottom of the trailer but I have no idea what that something would be. I does look like this was installed before the trailer was put on the metal frame. Now that it has come loose it this spot it is start to come loose in all the other spots. The trailer is only 1 1/2 years old at this point.
Thanks for any advice you might have.
ID:	140175   Click image for larger version
haplo777 is offline   Reply With Quote
Old 06-05-2017, 09:55 PM   #2
I had a similar situation when I blew a tire last year in Chicago on my way to Milwaukee. What I did was spray the wood with flex seal, then stapled on some corrugated material like realtor signs or political signs are made with, then I sprayed again with flex seal. I think it is better protected now than before.
Dinostop is offline   Reply With Quote
Old 06-10-2017, 08:36 AM   #3
King of the Road
Check Amazon for the term Coroplast.
Corrugated Plastic. That's what came on the bottom of mine. It's convenient but can be costly.
But it allows me to open a section and then can close it up again with 2X3 panels using #14 self tapping screws and gorilla tape for a water tight close.
Here's a link from amazon for a roll, but you can also buy this in different size "signage" sheets.
https://www.amazon.com/Coroplast-Pol...ords=coroplast
Also available at Lowes and HD in the signage section, but even more expensive.
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
