Old 11-11-2020, 12:05 PM   #1
Mouse intrusion AGAIN
There is absolutely no reason that mice and other critters should be able to get inside an RV except thru the front door! You wouldn't accept that in your car/truck why is it accepted in your very expensive RV?
It's a problem that Forest River needs to correct! My 2020 Wolf Pup 16FQ HAD a mouse entry problem where mice came in under the huge opening under the shower pan which is above the black tank. I removed the access panel under the shower and discovered a 14" x 14" hole in the flooring separated from the outside world by only a little insulation and that cheap netting which holds up the insulation. I could feel a strong draft coming from below and easily passed a stiff wire thru the insulation at a point where I could see a mouse tunnel which was visible above the black tank.
Local dealerships either refused to work on fixing my camper or scheduled well into 2021. I "fixed" the problem myself by cutting and fitting several panels of wood under the shower pan, gluing and screwing those to the floor, stuffing with wire mesh and filling with spray foam. Sorry, photo rotated 90į. This is before my exclusion.
leeboat is offline   Reply With Quote
Old 11-11-2020, 12:14 PM   #2
I say the same thing about my house, yet mice sometimes find their way in. It happens.
Just because an RV has wheels and travels down the road doesn't mean it's anything like a regular car or truck. It's more like a house on wheels.
Iwritecode is offline   Reply With Quote
Old 11-11-2020, 12:20 PM   #3
Mice and other rodents do tons of damage to cars and trucks also . getting in under the hood and chewing wires . i mouse proofed mine 6 yrs ago when i bought it and never a mouse in six yrs . this is something you should/need to do yourself . not a warranty issue part of RV ownership
MR.M is offline   Reply With Quote
Old 11-11-2020, 12:45 PM   #4
dbutton's Avatar
Spray foam alone is not enough to keep rodents out. This is where there was a large hole for wiring to enter the control tower. I foamed it then found this a few days later, the pile in the first photo is chewed foam! I went back & covered all gaps with 1/4 X 1/4 wire mesh then foamed over that. It seems to have worked. We have red squirrels here & they were doing the damage but I used a trail cam under the RV & saw mice, chipmunks & squirrels. 2nd photo is one squirrel chewing foam.
Yes, it would seem better to seal all holes with more than foam or insulation at the time of build but it seems RV companies don't see value it that!Click image for larger version
ID:	242848Click image for larger version
David & Mary Button - Ithaca NY
2011 Dynaquest XL 36' Freightliner
Cummins 330/1000
2009 Silverado 2500HD
2008 Corvette - 2011 BMW 335xi - Honda Valkyrie
dbutton is offline   Reply With Quote
Old 11-11-2020, 01:44 PM   #5
Daycruiser's Avatar
I have commercial rodent bait stations under my RV where they would climb to get into the RV. They smell the bait and go that route first never to see what the RV looks like inside. So far so good.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
Old 11-11-2020, 01:59 PM   #6
Trailer Park Supervisor
NJKris's Avatar
I've lucked out with my 2019. The bottom is completely covered with that chloroplast or whatever u call it, and cutouts for hoses/electric are completely and generously filled with expanding foam. If I ever notice any chewing on that stuff, I'm going to spray cyanide and arsenic on it, lol. And I live in a mouse heavy area, I've spent thousands repairing chewed up electric on my vehicles, i believe ground hogs are responsible. I shoot those things and stack 'em like cord wood, like that scene in the movie '300'.
NJKris is online now   Reply With Quote
Old 11-11-2020, 02:25 PM   #7
I've found that every hole that has a wire, drain, water pipe, gas line, etc has been cut far bigger than necessary and leaves plenty of room for mice to get in. The covering on the bottom has some gap around the edges and when the slide is out there is plenty of room around the slide mechanism for critters to get in. It's no wonder that mice love RV's.��
2018 Shadow Cruiser 265RLS
2018 Chevy Silverado 1500 with 5.3 max tow package
Shiawassee County, Michigan
Tacky is offline   Reply With Quote
Old 11-11-2020, 02:31 PM   #8
rsdata's Avatar
I use an electronic repellant inside the camper, bounce dryer sheets and Irish Spring soap inside all drawers in the camer.
Outside I use this Victor product sprinkled around all the wheels and replenish every month in the colder 1/2 of the year.
And I live rural where there are lots of field mice... So far so good.
2014 Shamrock 183
Old 11-11-2020, 02:32 PM   #9
Our RV is stored in our barn so out of the elements and on concrete. We use a pest control provider who puts rodent glue boards around the inside perimeter of the barn along with mouse bait. Plus we put the rodent glue boards around the tires. Between all these items, we've been rodent free (knock on wood).
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
jd4010 is offline   Reply With Quote
Old 11-13-2020, 05:53 AM   #10
Mice love Irish spring soap!! So if your soap not chewed on, well mice are not getting in. Donít believe?? Put some soap in a protective container outside and watch it disappear. Lol
dodgemark is online now   Reply With Quote
Old 11-13-2020, 12:28 PM   #11
NJKris's Avatar
Only if they are Irish mice. My mice here in NJ will probably go, "fugetaboutit"!
Old 11-13-2020, 12:46 PM   #12
Here's what mice do to Irish Spring soap in our part of the world. It's food for them.
To the OP.. you will find plenty more places than just that large hole under the shower for critters to get in. The factory enlarges EVERY hole (plumbing/electrical/heating) way more than necessary. It's part of RV life.
Oh... and I see it is your 1st post... Welcome to the forum!
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 11-13-2020, 12:48 PM   #13
dbutton... they are now making "pest block" spray foam. Not sure if it is any more deterrent or not?
Old 11-13-2020, 12:49 PM   #14
Flybob's Avatar
These bait stations have very negative side effects. The poisoned rodents leave the station and can be eaten by Owls. Hawks and Eagles. The end result is a dead Raptor. Not only is a bad practice, but in the case of an eagle it can result in a fine.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-13-2020, 02:55 PM   #15
If your RV was as large as your house, I might be able to understand your reply and why you're just gonna give up to mice. But my Wolf Pup has an underside dimensions of about 130 sq. ft. which should be modern manufacturing practices be easy to seal to exclude vermin. Mine with a 1 ft. sq. hole is almost large enough for my 85 lb. dog to get thru.
Old 11-13-2020, 04:50 PM   #16
Mandog's Avatar
I absolutely hate glue traps. They catch way to many good creatures.
Mandog is offline   Reply With Quote
Old 11-13-2020, 04:52 PM   #17
Mandog's Avatar
Wow I never new about this stuff!
Old 11-13-2020, 05:02 PM   #18
I cut and stuff this copper mesh into all openings underneath my campers: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I then use the spray foam through the mesh. So far, so good. The link I provided is a 100 foot roll, which is way more than you're going to need for a single camper. I also used it on my utility trailers I have stored in a rodent-prone storage lot.
2021 Solaire 260FKBS
2018 Chevy Silverado 2500HD 4x4, 4.10 axle
DocP is offline   Reply With Quote
Old 11-13-2020, 06:03 PM   #19
dbutton's Avatar
Thanks for posting this. Yes I did use rodent foam!
I also used this Honda tape for wiring repairs behind the dash & overhead wiring.Click image for larger version
Cummins 330/1000
Old 11-14-2020, 06:46 AM   #20
WolfPup16FQCT
Re. Irish Spring soap, just leave it in the box, don't remove it from the box. I used it in my previous camper (along with dryer sheets) for 10 years with no problems, and no mice. I used it in my Wolf Pup last winter, same thing. We'll see this winter.
WolfPup16FQ (2020)
Nissan Frontier 6cyl, 4x4 (2016)
MarsbarsCT is offline   Reply With Quote
