So, I just got my new 2019 Vengeance 377v toy hauler home. I'm posting here in the general forum since my questions aren't specific to any model.
It's raining right now and I'm wondering which areas I should be looking for leaks or wet spots showing up on a new camper with multiple slides?
Speaking of leaks - I'm doing my best to avoid any water damage at least till I make the first payment...
I hooked up city-water and pressurized the system(with a regulator in place)...found no leaks so far. I turned off the water-spigot valve and left it under pressure. I figure if it still has pressure after 24 hours - there are no leaks.
Still have to test a few more things before I'm satisfied it isn't leaking and everything is working 100%.
Try not to stress! Get yourself a flashlight, and a new habit of checking your water lines after hooking up each time, or when the system is pressurized with the pump and fresh tanks.
You’ll drive yourself insane!!!!
As far as rain, check your bathroom vent frequently, as well as all high corners and on top and under each slide.
