Originally Posted by 77kbrady
We just bought and are living in a 22 Cedar Creek Cottage. The walk through they gave us before delivery was minimal and not much help. Figured out most on my own, on you tube and through forums here but I am still stuck on a couple of things. We have gotten 3 hot showers and thats it. It seems like the water heater (fully electric) only works when it wants to. Have tried checking breakers, reset on tank, bypass. Its brand spankin new so I shouldnt have to be replacing things already should I? The tank was full and hot the first time we used it. After the first couple of showers it seemed like it didn't want to work. About a week later we got 1 more hot shower out of it and a couple of luke warm ones and thats it. Help! Oh... and can anyone explain what the set up is in front of the water heater. I can't remember if they even touched on it during the walk through.
Can you take and post more closer pictures of the water heater plumbing ?
from the pictures i can only see the hot out but not the cold in . is that a tee up where the pex turns from red to blue ?
This is a 120 electric water heater guess 19 gallons . normally a cold inlet on the bottom with the hot out on the top like in the picture . there is only 1 element in this water heater . there is a thermostat under the panel on the right that can be increased or decreased .
Still the plumbing doesn't look right but can't tell in the pictures which is why i requested more pictures .
