Originally Posted by TSman
I did not get any replies but spent all day trying to track this down. I finally found someone with the same problems on a GM truck forum. For anyone else with this problem, the solution was a bad starter/run relay, relay #15 in the engine fuse box. You can test it by swapping it with the #40 AC relay to see if it works.
The problem was tough because it started with a check airbag warning. This message went away as soon as the relay was changed.
This is a great Forum but I was a little disappointed that I received no replies.
Good diagnosis and test. I just walked my son through something similar.
Here's a suggestion for unit-specific questions like yours:
Near the top of the page, in the thin green bar, is "Registry." With some pain, you can search all of the registered users and find some with the same year, model, and chassis as yours. You can then send each of them a Private Message (PM) which may cause them to be more responsive (except for Ducky who doesn't like PMs).
Unfortunately you will find that the data is kind of dirty. It really needs to be groomed. You will find some entries under S for Sunseeker, some under F for Forest River Sunseeker, and other combinations. I find that it sometimes takes four or five scans through the data to catch all potential owners.
I'm not sure the Registry is ever cleaned, either. If someone dies, changes his email address, or even sets a filter to send all FRF communications to Trash, he will probably still be in the Registry.
For sure, it would be a much better feature if it were groomed.
