07-04-2016, 01:18 PM
MCTroy
Not so fantastic fan
I did a quick search but didn't find any info on servicing the fantastic fans. We have the basic model in our bath. It is a 2015 so just a year old and still under the extended warranty. It is getting noisy. When running on either speed it squeaks. I tried a good shot of WD40 And it didn't help. Any suggestions on how to quiet it?
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
07-04-2016, 01:28 PM
WD-40 isn't actually a lubricant so try some some light machine oil.
Better to contact the FF people as they're support is fantastic (pun intended). I once had a problem with the plastic surround melting while my A-frame, years out of warranty, was stored in the Phoenix summer heat. I contacted them about buying replacement parts. They asked what year trailer. When told, they said that was the year they tried another plastic formulation that didn't work out. They sent me all the parts I needed to repair the fan free of charge. Now, THAT'S customer service.
Jerry
2007 Surveyor SV 230
2013 F150 Ecoboost
07-04-2016, 01:29 PM
You say it "squeaks" well I think it's a sealed motor so WD40 will not help. Is it loose in the housing the 14x14 opening and the blade is making it move, is it reversible? will it also do the same thing? might need a new motor then.
Coachmen M/H
Concord
2018 / 300 DSC
07-04-2016, 04:20 PM
MCTroy
Not reversible. I will take the screen off and see if anything is loose. I don't feel anything but can't get to the motor with the screen on.
The light weight oil might help too.
Thanks!
2018 Ram 2500
Ohio River Rat
07-05-2016, 12:14 PM
search for youtube videos on cleaning and taking apart fantastic fans to take everything apart... motor should not squeak... the fan might be loose in the housing and it rubs slightly somewhere
2014 Shamrock 183
07-05-2016, 04:46 PM
Warranty
I thought Fantastic Fans had a lifetime warranty. I would call the factory and check.
07-05-2016, 06:13 PM
Swift2
Are covers on the 2fantastic fans open so slow we wonder if they are even opening. Other fans we have watched are much faster. Other fans we have watched are much faster
07-05-2016, 06:54 PM
I have a quick question since e you say it is a 2015 why are you trying to fix it here? just contact the fan company or better yet FR or the warranty company I am sure any of them will be happy to help you fix the fan. since you say it squeaked and it is a sealed motor it most likely has a bad bushing, so just have it replaced and then you and your family can get back to enjoying your coach for the summer?
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
07-05-2016, 07:01 PM
MCTroy
We are trying to fix it until we get back to our dealer in September. Thanks for ask the advice, I will try opening the screen to see if anything is loose. Thanks for all the tips.
2018 Ram 2500
Ohio River Rat
07-05-2016, 07:03 PM
If you mess with it you may void the warranty.
Here is the warranty info:
http://www.fantasticvent.com/assets/...y_overview.pdf
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
07-05-2016, 07:48 PM
I had an issue with one of my Fantastic Vents that was in Warranty, called my dealer and they were no help at all. I find going to a dealers with warranty issues are worthless so I went online and got the support folks from
Fantastic Vent to help, amazing experience, not only were they helpful but shot out my needed part that day and I got it within 4 days. Might I suggest if you are going to be somewhere for an extended time, say a week, give them a call ahead and see if they can expedite to you whatever you need to where you will be.
07-05-2016, 07:53 PM
X2
The warranty for the fan ( and most other appliances) is from the appliance manufacturer and not FR. Call them. Odds are they will send you the part and instructions if you want to do it yourself or provide you with an authorized dealer close to you that can do it for you.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-05-2016, 08:06 PM
I had the squeaking issue from our previous trailer. Looked like the motor bracket was supposed to be mounted on rubber feet or a spacer yet it was screwed right to the housing causing the fan blade to be too close to the screen. I took the pop out screen off then the blade off the motor so I could remove the motor bracket screws and placed four stainless small nuts as spacers to raise the fan up a bit. I'd like to see the parts list on the fan assembly as I suspect someone left a few out on the install.
07-06-2016, 07:30 AM
A little off subject but,,, WD40 is not the magical spray many think it is !!!
WD stands for Water Displacing !!!
07-06-2016, 08:35 AM
Sacrilege.... get the torches😂
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
07-06-2016, 09:03 AM
It has always been thus...but does that exempt it from being a lubricant?
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
07-06-2016, 12:45 PM
In many cases, WD-40 actually rinses off the lubricant. Then, when it evaporates, it leaves nothing behind. It is excellent, for what it was meant to do. At other things, it can make matters worse.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
07-06-2016, 01:00 PM
Damn, all that lubrication I've done with WD-40 over the past 40 years...wasn't!
By the way, oil displaces water too...
07-06-2016, 01:03 PM
Hmmm. "Excellent for what it was meant to do." What's it meant to do?
Their website says "drives out moisture, protects, frees sticky mechanisms, removes, lubricates."
WD-40 EZ-REACHâ„¢ 14.4 OZ
Not saying I necessarily agree with all of these, but the company clearly thinks it lubricates.
2011 Traverse LT, 3.6L, FWD
07-06-2016, 08:40 PM
Water Displacement. Intended to be sprayed on the inside and outside of a wet distributor cap of a stalled military vehicle so it can be restarted after the distributor takes a bath in a creek, pond or puddle. Made for the military.
Oil a squeaking door hinge in your house with it and see if it don't need it again within a couple of months. Not a good lube.
